Hairspray??
Old Jun 1, 2006 | 10:10 AM
Rusted40's Avatar
Default Hairspray??
anything you guys use to keep the cold side hoses on?
just short of weatherstrip adhesive at least...
I have been told hairspray works well
Old Jun 1, 2006 | 11:10 AM
LASTLS1's Avatar
6 Second Club Moderator
It use to work pretty good on the hand grips racing motocross????
Old Jun 1, 2006 | 11:40 AM
CHRISPY's Avatar
yup works great!
Old Jun 1, 2006 | 11:56 AM
RyanJ's Avatar
SSU Moderator
I heard hairspray works real good...almost too good (if you take your pipes on and off a lot). Do your pipes have a bead around the ends?
Old Jun 1, 2006 | 12:46 PM
Boostaholic's Avatar
Hair spray will work wonders. When I took my cold pipes apart after letting them sit over the winter it was a BITCH.
Old Jun 1, 2006 | 03:32 PM
Rusted40's Avatar
I cannot tell a lie
the pipe in question does not have a bead
guess I'll weld some on first...
the hairspray I can borrow from my sister if she uses it
thanks for the input guys
Old Jun 1, 2006 | 03:35 PM
MrDude_1's Avatar
if not, you can barrow some from most thirdgen owners..
If you have beads on both sides and tbolt clamps you won't be blowing things apart hairspray or not if your blow off valve works.
Old Jun 1, 2006 | 03:59 PM
RyanJ's Avatar
SSU Moderator
Hey! I only use the spray on the front of my hair...that feathered affect doesnt happen by itself, ya know. The back I keep long and natural.
Old Jun 1, 2006 | 05:07 PM
Ping King's Avatar
party up front..business in the back
EDIT:
business up front...party in the back
got it right this time.
Old Jun 2, 2006 | 12:12 AM
engineermike's Avatar
Use high-quality dual-density silicone couplers and weld a bead around the pipe and you won't have a problem, even with cheap hardware-store stainless hose clamps. I've been over 24 psi like that with no problems.
Mike
Old Jun 2, 2006 | 07:59 AM
Rusted40's Avatar
ya t-bolt clamps and silicone couplers are the only way to go
I welded beads on the offending pipe and so far so good
before the pipes were blowing off at 22psi
