bleeding off boost with this cam
Old Jun 3, 2006 | 02:39 PM
deadmanTA's Avatar
Default bleeding off boost with this cam
I've been kicking around the idea of a turbo for a while still not sure, but if i did how much bloost would i lose with my cam.
could i run higher boost to compensate?
Old Jun 3, 2006 | 02:40 PM
deadmanTA's Avatar
oh yeah i do know i would have change heads to lower the compresion
Old Jun 3, 2006 | 04:05 PM
engineermike's Avatar
First off, a large cam does not "bleed off boost" with a turbocharger. The 2x higher exhaust backpressure prevents that from happening.
Secondly, with a turbocharger, you set the boost pressure using the wastegate and boost controller. So, if you set it for 6 psi, then it stays at 6 psi no matter what cam.
Third, when asking a question about a cam, it would be nice if you give the cam spec's.
Mike
Old Jun 3, 2006 | 04:12 PM
deadmanTA's Avatar
its the tsp 228r 228/228 588/588 114lsa on xe-r lobes, just wondering how well it would work on a turbo setup
Old Jun 3, 2006 | 04:19 PM
It will work fine.
Old Jun 3, 2006 | 04:34 PM
deadmanTA's Avatar
That gives me some thinking to do. thanks for the help
Old Jun 3, 2006 | 04:38 PM
Phil'sC5vette's Avatar
I just bought that cam. Maybe I should do some forced air
Na, that's a little to much for me
Old Jun 3, 2006 | 05:45 PM
deadmanTA's Avatar
should be a nice setup with those heads
Old Jun 3, 2006 | 06:53 PM
SilverSS's Avatar
That cam will work fine. I'm boosting with a large cam and it still makes crazy power.
Old Jun 4, 2006 | 09:49 AM
deadmanTA's Avatar
The size of the cam doesn't concern me it is the aggressive lobe profiles.
Old Jun 4, 2006 | 06:41 PM
DeltaT's Avatar
Why would the agressive lobe profile bother you? You put in the right springs with the cam, right?
Jim
