Victor Jr.
Old Jun 8, 2006 | 03:01 PM
FormulaFire's Avatar
Default Victor Jr.
I have decided to move up from a ls6 to a Victor Jr. intake on the T88 turbo 391 LS2 after doing some research. I think it would be beneficial. I've also read that some people have had some trouble. Where is the best place to get one? I would like an elbow that wouldn't require any hod modifying or milling.. I read that Tiago used Speed inc. fuel rails instead of the edelbrock ones. How much more beneficial would this be? I know that the Speed Inc. ones are a little larger.. How well would it work? ANy other input? THANKS
Old Jun 8, 2006 | 03:14 PM
Tiago's Avatar
the speed inc rails are 1/2" ID (maybe even 5/8") while the edelbrok were 3/8", so I kept my speed inc rails on it, just took a couple of custom brackets
Old Jun 8, 2006 | 03:28 PM
Got Me SOM's Avatar
Tiago did you have to cut the cowl? I'd like to run one of those single plane intakes for the cool factor but I don't want to have to cut anything.
Old Jun 8, 2006 | 03:29 PM
well.. you were my original inspiration for the victor Jr... If I bought just the victor jr. intake, which one should I get for my engine? Where'd you get yours from. I'll probably get an elbow from nitro dave(since there is no modding required).. If I went with speed inc rails.. COuld you possible make some brackets for me? and what inkectors are you running? I read that they were a PAIN for you to put in..
Old Jun 8, 2006 | 04:03 PM
under pressure's Avatar
I just measured my Edelbrock fuel rails. They are indeed 1/2" inner diameter, not 3/8". The rails are threaded for -8 fittings, so I cannot imagine a flow restriction problem even with the largest injectors. The brackets that come with the kit work fine. You could spend a lot more for custom rails and brackets though if you wanted the "look".
Old Jun 8, 2006 | 04:15 PM
snketr's Avatar
What all has to be changed to run a victor? intake, fuel rails, elbow...... then what?
Old Jun 8, 2006 | 04:33 PM
Slowhawk's Avatar
LS1Tech Sponsor
The Edelbrock rails are fine for 1400rwhp.So why not use what fit's easilly The intake will work great.
Old Jun 8, 2006 | 04:43 PM
Solves that problem.. `1400rwhp is def. enough!
Old Jun 8, 2006 | 05:02 PM
BlackCamaroSS02's Avatar
I have been waiting months for my complete manifold w/ plenum, rails and TB from nasty performance, been on backorder forever. i cant wait till it comes in its gonna be wicked on my 408 T88 build.
Old Jun 8, 2006 | 05:08 PM
MiaSSmaro98's Avatar
im building my home made kit soon using a t70 turbo around 7 psi daily driver.how much more power will i gain with the edelbrock over an ls6 manifold?i mean i have to buy the ls6 so if the edelbrock offers a power gain over the ls6 then i'll just buy the edelbrock
Old Jun 8, 2006 | 05:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
Here are some pics of the Victor with Intake Elbow's.com 90' and rails.Don't go by the fuel system sice it's for a Vette
Attached Thumbnails Victor Jr.-dsc02339.jpg   Victor Jr.-dsc02340.jpg   Victor Jr.-dsc02341.jpg   Victor Jr.-dsc02342.jpg
Old Jun 8, 2006 | 05:40 PM
F8LWS6's Avatar
Just got my Vic Jr in today from Synergy. The rails and lines look like plenty enough to me!
Old Jun 8, 2006 | 10:15 PM
dacajun's Avatar
Slowhawk,
That's a cool setup you have there. Will that fit under a C5 hood? I'm looking at a cowl hood with a 3'' rise to it, I'm sure that should clear the setup you have. I may go this route also so please keep me in the loop as to how it's work out for you.
Thanks,
Dave
Old Jun 9, 2006 | 05:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by dacajun
Slowhawk,
Thanks,
Dave
It is 1" too high for a stock C5 hood so we got a cowl setup.Should fir under a Z28 hood ok.
Old Jun 9, 2006 | 06:27 AM
Inspector12's Avatar
TT-TECH Veteran
Looks good that fitting for the brake booster is going to be tight although it is the same place I am mounting my regulator etc...
Old Jun 9, 2006 | 10:03 AM
The LS6 intake has worked nicely with turbo applications. I have a customer with twin 60's and the LS6 intake that makes wicked power in his buggy. My thinking is that it might even be superior to the Victor Jr. in a lower boost, under 800 horsepower situation. The longer runner length may work to the advantage of quick response. Again, cam selection and how the parts work with each other determines a lot of the outcome. After saying all of that, I bought the Victor Jr. Costs less and is so easy to adapt to different applications - looks good on there too.
Old Jun 9, 2006 | 10:05 AM
snketr's Avatar
The victor jr doesn't have the problem of making #7 lean either, does it? That would be the biggest benefit to me. A little more "insurance"
Old Jun 9, 2006 | 10:21 AM
Lason's Avatar
Thats the same reason Im planning on using one. No question to #7 getting the same amount of air as the rest of the cylinders with the victor jr.
Old Jun 9, 2006 | 11:40 AM
so victor jr. it is then.there are elbows out there that fit under the stock hood right? i have a 98 ss if the matters
Old Jun 9, 2006 | 11:54 AM
I believe Nitro Dave makes some that won't require modding.. Correct me if I am wrong.
