where does this go
Old Jun 8, 2006 | 10:12 PM
JerikSS's Avatar
Default where does this go
In a turbo set up where does this sensor go....?
Old Jun 8, 2006 | 10:15 PM
ddnspider's Avatar
it looks like an IAT sensor but i could be wrong
Old Jun 8, 2006 | 10:45 PM
JerikSS's Avatar
Its the one that goes on the airfilter assemly. Just want to know what to do with if when Im done with turbo install.
Old Jun 8, 2006 | 10:47 PM
ddnspider's Avatar
you have to drill a hole in ur cold side pipe( close enough to plug the sensor in and connect it) and put the grommit in there and then pop that in.
Old Jun 9, 2006 | 12:22 AM
JerikSS's Avatar
Should it go before or after the maf? Before or after BOV?
JerikSS's Avatar
also, what happens if I dont connect it??? dont want to loose any boost
Old Jun 9, 2006 | 01:29 AM
98turbls1's Avatar
I would say before it sinced it's before it in the first place...I don't think that it really matters if it's before or after the bov because it's basically just going to get a reading to know when the temperature changes...
Old Jun 9, 2006 | 10:13 AM
JerikSS's Avatar
so no big deal if i dont plug it in. I can just tune it out with hp tunners.
Old Jun 9, 2006 | 10:20 AM
ddnspider's Avatar
no you need that sensor plugged in.the ECM takes into account that sensor to figure out fuel and timing.Its not that big of a deal to make a hole and put it in.
Old Jun 9, 2006 | 10:22 AM
98turbls1's Avatar
I agree...I would definitely say that you need it...
Old Jun 10, 2006 | 01:01 PM
reocamaro's Avatar
Are there any negative effects w/ installing that sensor in inbetween the throttle body and the MAF? STS kits have that set up.
