View Poll Results: What Boost
7lbs
4
8.51%
8lbs
21
44.68%
9lbs
10
21.28%
10lbs
12
25.53%
Voters: 47. You may not vote on this poll
Another Boost question POLL
Old Jun 11, 2006 | 04:07 PM
JerikSS's Avatar
Default Another Boost question POLL
What max boost with a turbo would you guys run on a stock bottom end with lq9 heads, intank fuel tank, injectors, ls7 clutch and a 232/228 .595/.588 115lsa turbo cam?
Old Jun 11, 2006 | 04:12 PM
~JOSHUA's Avatar
Boost is also relative to flow. Like on a supercharger with a fixed pulley porting those same heads will make the actual manifold pressure go down.
Old Jun 11, 2006 | 04:19 PM
2002/Black/SS's Avatar
i would say 9 pounds if u didnt have the cam and 8 with the cam
Old Jun 11, 2006 | 04:31 PM
JerikSS's Avatar
yeah i have a big cam
Old Jun 11, 2006 | 05:17 PM
SuperZ's Avatar
alot of it depends on if you run meth injection or not and what size turbo.
Old Jun 11, 2006 | 10:40 PM
JerikSS's Avatar
it looks like i am going to keep it at 8psi, wonder how much power I will be making....
Old Jun 12, 2006 | 11:52 PM
JerikSS's Avatar
anyone interested in the poll
Old Jun 13, 2006 | 05:52 AM
Superman09's Avatar
LS1Tech Sponsor
As SuperZ asked..... will you be using meth.... what size turbo?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 13, 2006 | 06:53 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I say 10 psi. I ran 10 for a while on a stock bottom end with a SC. No problems to report.
Old Jun 13, 2006 | 07:23 PM
JerikSS's Avatar
no meth and the turbo is a t76
Old Jun 13, 2006 | 10:49 PM
Mike 01WS6's Avatar
Have run 10.5 for 10k miles, with no issues what so ever.
Old Jun 14, 2006 | 02:13 AM
JerikSS's Avatar
The votes are between 8 and 10... how about 9? Just want it to be safe, not exactly rich or anything, and this stuff is expensive...
Old Jun 14, 2006 | 05:49 AM
longrange4u's Avatar
LOL Ask me what happened to my TA when I started running 10lbs plus on almost that exact config.....
Old Jun 14, 2006 | 03:47 PM
JerikSS's Avatar
I actually now remember reading your post a while back, sorry about your engine dude. The numbers on your sig what boost level was that??
Old Jun 16, 2006 | 09:08 AM
mdhmi's Avatar
I didn't see an option for 12 #'s.
You can run more than 7-8 lbs if you've lowered your CR and run good fuel. It was explained to me that it can be safer to run more boost with a convervative tune than run low boost and a walls to the wall tune.
Old Oct 7, 2007 | 11:54 AM
ddnspider's Avatar
i would like to know the basis for this that going from a stock cam to a 23X cam drops 1 psi
Old Oct 8, 2007 | 03:37 PM
Zombie's Avatar
where is the 15psi option?
10PSI will be OK with a good tune. The tune is the most important part of the setup.
Old Oct 8, 2007 | 03:41 PM
geeteego's Avatar
Mine didn't fare well at around 8 psi...stock heads, though.
Old Oct 8, 2007 | 03:42 PM
67Firebird455's Avatar
If you want it to be "100%" reliable, run 8. I ran 8 and started getting KR on my rig, a lot to do with tune. I ran 5 and didn't get KR, so... I also believe 10psi is doable with a correct tune, none of this mail order stuff.
