SBF headers and LS1 flanges?
Old Jun 13, 2006 | 07:04 PM
Bird-Of-Prey's Avatar
Default SBF headers and LS1 flanges?
I remember reading somewhere on this forum last year about the possibility of using SBF headers and cutting off the flanges and welding on LS1 flanges. They were saying that the pipes prety much lined up with little to no modification. You just had to weld on the new flanges. Has anyone heard of this before? Do you guys think it would work? Anyone with a SBF that could measure the distance from the center of one pipe to the next?
I've seen many SBF twin turbo manifolds recently and some of them look like they would fit if the pipes lined up. Prices are a lot less than the LS1 too. Here's a pic of a set I am looking at.
Old Jun 13, 2006 | 08:39 PM
Brains's Avatar
They line up perfectly. I've done this myself for my Mustang project.
Old Jun 13, 2006 | 08:55 PM
Nine Ball's Avatar
LS1Tech Co-Founder
No ****? Maybe we could just order those 5.0 headers without flanges welded on....
Interesting
Old Jun 13, 2006 | 08:59 PM
Interesting
My thoughts exactly. They sure do look like they would work.
Old Jun 14, 2006 | 06:31 AM
smokinHawk's Avatar
my bet is they dont clear the shock towers, an fbody is tight between there.
Old Jun 14, 2006 | 06:54 AM
rons 00z's Avatar
but isnt it on a mustang also?
Old Jun 14, 2006 | 09:40 AM
snketr's Avatar
Come on, be the guinea pig for us. It's only your money, not mine.
Old Jun 14, 2006 | 12:54 PM
dacajun's Avatar
Why not just call the header manufacture and ask them to do the LS1 flanges. This should have no effect on there header jig and plus is now expands there inventory.
Any idea who builds the ones Bird-of-prey posted in the pics above ???? Find out who builds them and I'll make the call...
-Dave
Old Jun 14, 2006 | 01:56 PM
Brains's Avatar
You couldn't just haphazardly weld the flanges on, without mocking it up on the motor in the car. The angle and position of the cylinder head is different from a 5.0L Ford to the LS1.
Old Jun 14, 2006 | 02:24 PM
FUroundeye's Avatar
-Dave
www.turbotechnologyinc.com
Old Jun 14, 2006 | 03:15 PM
N20Silverado's Avatar
I looked into this option, as Mustang turbo kits are eaiser to find and way cheaper. I came to the same conclusion as smokinHawk. The frame rails and shock towers are not wide enough. I didn't actually have any to try, but I didn't think it was cloes enough to risk the $$$ to find out I was wrong.
Tim
Old Jun 14, 2006 | 08:35 PM
After looking at it a little closer and taken into consideration that on an LS1 head the exhaust is more straight up and down (less angle) than a SBF there most likley isn't enough room. By setting the headers at less of an angle you would actually make them wider. Too bad as I really like this design. Looks like it would place the turbos right where you would want them too.
