keep the 226, or return to stock cam
Old Jun 14, 2006 | 09:46 AM
11secLS1's Avatar
Default keep the 226, or return to stock cam
Well, Right now I have a 226/226 .575/.575 114+4 cam installed in my car along with some MTI stage 2 heads. However, I am still running stock manifolds with a loudmouth. I am about to order a D1SC Procharger. Would it be better to leave this cam in or put the stock stick back with the addition of the procharger? Any advise is welcome.
TIA
(I know that I need longtubes but I will not be adding them)
Old Jun 14, 2006 | 10:11 AM
Slowhawk's Avatar
LS1Tech Sponsor
Matter's what the compression is on the heads.If it is 10.5 or higher I would leave the Cam to bleed of some compression.
As you would expect.Not running longtubes with a H/C and blower is not a smart move.
Old Jun 14, 2006 | 10:58 AM
11secLS1's Avatar
Why is this not a smart move?
Old Jun 14, 2006 | 12:46 PM
snketr's Avatar
Forcing all that air in and restricting it on the way out? Think of it as air trying to get out of a baloon. It's takes a while b/c the outlet is restrictive. Bigger outlet=more air goes through faster.
Old Jun 14, 2006 | 01:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
-Add headers for sure
-That cam is fine, you don't need a big split cam for lower boost levels, and you will make over 30rwhp more than you would with the stock cam
Old Jun 14, 2006 | 02:14 PM
~JOSHUA's Avatar
I bet the blower has drained the budget, but if you can get some coated Pacesetters and an off-road y-pipe ($500 for everything) the engine will breathe much easier and you'll pick up big hp from the headers.
Old Jun 14, 2006 | 04:08 PM
11secLS1's Avatar
I know that with headers this cam would be better than the stock cam, but given the fact that I have stock manifolds (and will NOT be adding headers), I was thinking maybe the stock cam would make a little extra power. Maybe I should get me a CheatR cam from thunder?
Old Jun 14, 2006 | 04:21 PM
snketr's Avatar
Why will you NOT add headers?
Old Jun 14, 2006 | 04:24 PM
11secLS1's Avatar
I had a set of hooker LT's, and a set of Kooks LT's, and I grew tired of the noise, both interior and exterior. So I replaced them with stock 02 cast iron manifolds, cats and Y-pipe, and have never been happier. I guess I'm just getting old and this is just a street car.
Old Jun 14, 2006 | 04:43 PM
LS1Tech Co-Founder
Keep cats then.
I see no reason to go backwards on cam.
Old Jun 15, 2006 | 04:15 PM
~JOSHUA's Avatar
Headers with a catted y-pipe will be added in the future anyway, you just dont know it yet.
Old Jun 15, 2006 | 05:04 PM
11secLS1's Avatar
I ordered a TR CheatR cam today. Lets see what happens.
