tt408 first dyno fun
Old Jun 15, 2006 | 07:32 PM
kindaslo's Avatar
Default tt408 first dyno fun
Hp performance just got my c5 finished up and is dynoing it with the stage 2 turbos.
8 psi netter 630hp/670 tq
valvefloat seems ot be a problem as the motor wont rev past 6000 rpm.
I have comp 921's, what springs are boosted guys running??
Old Jun 15, 2006 | 08:25 PM
Boostaholic's Avatar
wtf that seems awful low
what kind of setup do you have for intercooler? what were your AFRs and knock at?
Old Jun 15, 2006 | 08:45 PM
LASTLS1's Avatar
6 Second Club Moderator
He's @ 8psi though!
Old Jun 15, 2006 | 11:43 PM
kindaslo's Avatar
pulled 1 degree of timing for knock..
its only 8 psi, and on a msutang dyno, and it floats the valves at 5800 rpm.
My main questions is what valve springs work well for boosted cars?
Old Jun 16, 2006 | 12:12 AM
SSilverSSurfer's Avatar
nice numbers for the amount of boost...what motor you runnning?
Old Jun 16, 2006 | 12:34 AM
NA$TY-TA's Avatar
hmmm something is wrong......
Old Jun 16, 2006 | 12:53 AM
Zombie's Avatar
What gap plug are you running? Close the gap to .025 if you haven't yet, could be experiencing spark blow out. You could also adjust the dwell time.
I highly doubt it's valve float at that low of an rpm.
Old Jun 16, 2006 | 12:54 AM
DeltaT's Avatar
At 8#, those springs should be fine, they're 135# on the seat and 400# at their peak - I don't think the boost will be holding open the valves at all, unless the cam is super-radical and right on the edge of lofting them already. I also doubt the spark is being affected unless you've really fouled your plugs.
Jim
Old Jun 16, 2006 | 01:41 AM
kindaslo's Avatar
8.5:1 compression all billet 408 stroker... lq9 heads.
Old Jun 16, 2006 | 01:43 AM
kindaslo's Avatar
Jim
I don't think the cam is too big. 236-242 600 lift i think..
it has the comp shaft mount rockers, and comp-r lifters.
It had the comp 918's on it when it was n/a and I had this exact same problem, but switching to the 921's fixed the problem..
Old Jun 16, 2006 | 01:58 AM
LASTLS1's Avatar
You know I made the same power at 6000 as I did at 7350? Maybe you will make more at a higher rpm. What's the rest of your set up?
Old Jun 16, 2006 | 08:36 AM
MIGHTYMOUSE's Avatar
got a way to measure your exhuast backpressure? are there pictures of this set up?
Old Jun 16, 2006 | 09:44 AM
Tiago's Avatar
for 8 psi and a mustnag dyno, I think they did just fine.... I wouldn't worry about anything. The graph will tell you if you had valve float.
Old Jun 16, 2006 | 11:52 AM
kindaslo's Avatar
Measure backpressure... negative. It's straight pipe though lol.. Redneck style. I'll get video up of it soon enough.
As far as pics go, this is what I have.
Attached Thumbnails tt408 first dyno fun-dsc00932.jpg   tt408 first dyno fun-dsc00935.jpg   tt408 first dyno fun-dsc00934.jpg
Old Jun 16, 2006 | 11:53 AM
kindaslo's Avatar
its an all billet 408 stroker wiht lq9 heads ported locally, comp cam, etc etc. nothing too wild, but hoping to make 1khp..
Old Jun 16, 2006 | 01:52 PM
BACKPRESSURE BEFORE THE TURBO
Old Jun 16, 2006 | 03:35 PM
TwnTrboCE's Avatar
I run that same spring but shimmed. I don't float till 7400+ @ 25+ psi. I doubt it is the springs. But would shim them if your looking to make that much.
Old Jun 16, 2006 | 04:59 PM
Got Me SOM's Avatar
looks like it is making great power. on pump gas with more boost it looks like you'll be able to make power in the 700's with ease. AWESOME
Old Jun 16, 2006 | 10:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Stick? How much max timing, just to give us an idea?
I am running 977's right now I think, I'm kind of forgetting. You want to run a lot of spring for blower cars, and even more so for a turbo car. I had Crane 832's but when I stepped up my cam my car fell off at 6100 rpms. Last time it peaked at 6600, T400, ~754rwhp, conservative tune C16 + 21 degrees of timing.
Old Jun 17, 2006 | 10:30 AM
mdhmi's Avatar
You shouldn't be having any valve float issues with Comp 921's. Tons of turbo folks are running those springs.
