Best F/I Intake Manifold
Or is it just because it's a multi-piece part that actually has smoother transitions that help elimintate some of the faulty #7 flow issues and is cheaper to make? Is it that the slight loss at the low end to the LS6 is made up for above 6,500???
I have a simple little out of the box turbo car that can be driven daily. I took the kids to school and drove to work in it 4 out of 5 days last week. It'll run 9s on pump gas and it only took a LS2 intake to do it.
I'm simply saying you can get it done either way. You can spend you're money where you like but just make sure it's the way your tuner likes to play.
Rick
Rick
I would take Mike Brown's word for it also, they have been ahead of the curve on FI LSx motors for a while now.
Unless someone puts their engine on an ENGINE dyno and does a back to back comparison no one will convince me the current single planes will be better then an LS6 under 1000hp on a boosted LSx. I would be more then happy to have someone prove me wrong, at this point swapping an intake to pick up even 20rwhp would be pretty cheap
Rick
If you like one buy one, I just think cowl trimming, extra weight and cost arent justified without some better data.
with the vic JR you do have to trim... i actually have the gmpp getting mocked up on my motor right now along with a Aarons elbow and holley 90mm TB
What we need is a stock cube LS1, stock cube LS2 and a LSx 427 all set to pull to 7K. We'll see that as the RPMs go over 6,500 and the cubes go up that their is going to be some shuffling in the numbers.
Now who is donating the testbeds???
Rick
... i hope
