Can you have a tune for two boost levels?
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
i def know with a standalone you can run whatever you like. the ECU will just compensate for the extra air with more fuel (as long as its in the look up tables).
thanks Chris.
I run two boost levels, one with no meth and one with meth. I just turn the boost up with the meth on until I get the a/f I want after it's tuned for 91 octane. At least that's what I did before.
91 octane has let me go 15psi so far, still have to play with the meth
dont it just measure more air untill it is maxed out?
You'll run slightly rich when it's closed but be right on when you open up the dump.
Rick
