Need Help with MSD... FI related.
Old Jun 26, 2006 | 08:36 PM
Ryan K's Avatar
Pathological Modifier
Default Need Help with MSD... FI related.
Hey guys I need to help MSD understand that there is interest in making the 6010 controller better for FI guys.
Read this post and reply:
http://www.msdignition.com/forum/showthread.php?t=5909
Thanks,
Ryan Karasek
Old Jun 26, 2006 | 09:06 PM
frcefed98's Avatar
So you are using this box to bypass the factory PCM?
More info on this set up please.
J
Old Jun 26, 2006 | 09:30 PM
Ryan K's Avatar
Its a great setup, it controls the timing somewhat standalone. It reads the Cam and Crank position sensors in parrallel with the Fatory PCM. That way the factory PCM still controlls everything except timing.
It is configurable for 1, 2, and 3 bar MAP sensors so it can change timing bsed on boost level. I think its key features are a integrated two-step and high rpm limiting. And it has the ability to retard timing. I am hoping that they will modify to software to make the product alittle better for us FI guys by making the retard function as an advance when running Meth and change the way they have their timing vs map tables layed out.
Ryan K.
Old Jun 26, 2006 | 10:21 PM
frcefed98's Avatar
Excellent set up. Lets hope we can get them to change it up for us FI guys. Have you been able to use the two step feature on your car?
Thank for posting this up, I for one didnt even know this was an option for tuning, just figured HPT/EFIlive were the only things going right now.
J
Old Jun 26, 2006 | 11:07 PM
sytyjedi's Avatar
Are these features of the MSD controller not available in HPT/EFILive solutions? I'm not to the tuning stages yet, so I'm unfamiliar with what options/features are available with each package.
Old Jun 26, 2006 | 11:12 PM
98turbls1's Avatar
J
I've posted the possible advantages of this setup a long time ago and it was moved to somewhere else...I'm going to be trying this out but I'm still waiting for the harness to integrate into the factory pcm...It's been on back order for a while but should be here soon...
Old Jun 26, 2006 | 11:17 PM
Ryan K's Avatar
The Two step and High RPM Rev limiter are not functions of EFI Live or HPT. THe factory PCM uses a Fuel Cut off that in my Opinion is not the right answer.
Everybody needs to post to that thread on MSD's forum so that this gets the attention it needs to move forward...
Old Jun 27, 2006 | 12:26 AM
98turbls1's Avatar
I totally agree Ryan...It would be really great if MSD would listen to our needs...I'm definitely going to post up so that we can get the required attention we need...
Old Jun 27, 2006 | 10:27 AM
Ryan K's Avatar
Back to the top, I think that this would be a great controller for us FI Guys!
Ryan K.
Old Jun 27, 2006 | 10:34 AM
98turbls1's Avatar
Ryan do you actually have the controller on your car yet??
Old Jun 27, 2006 | 11:21 AM
Ryan K's Avatar
Yes, I do. I recieved the special harness a couple of weeks ago from summitracing.
Old Jun 27, 2006 | 11:24 AM
98turbls1's Avatar
I ordered mine from Thunder racing and it has still yet to get here...I call them from time to time but no luck...How's the install?? I'm really excited to intall mine...
Old Jun 27, 2006 | 01:40 PM
frcefed98's Avatar
TTT for you ryan and for us LS1 FI peeps, post up be heard.
Old Jun 27, 2006 | 10:07 PM
Ryan K's Avatar
Anybody else wanna see a better product for our cars?
Old Jun 27, 2006 | 11:56 PM
98turbls1's Avatar
I replied to your thread...I hope that they listen to us and it would be nice if they could come out with it soon... =) BTW what are you running for fuel management?? I was thinking of megasquirt or something like that...
Old Jun 28, 2006 | 01:57 PM
frcefed98's Avatar
tttft
Old Jun 28, 2006 | 02:29 PM
stang90gt50's Avatar
Ryan K.
I just purchased a 6010 box myself and havent gotten it yet. The built in two step, nitrous retard, boost timing control etc all for $200 shipped I paid! GREAT DEAL.
Question: What do you want different as far as the timing vs map tables? I read the link regarding timing vs boost and it appears to allow you to set in retard of timing for boost pressure. The more boost the more timing you can pull out. Whats the problem there?
Also: On the timing advance/retard you want for methanol. Have you thought of hooking it up in reverse? Where the timing retard is "ON" when methanol is not working and have the timing retard turn "OFF" when the methanol comes on?? That would do what you want, just kinda backwards...
Old Jun 28, 2006 | 05:12 PM
Ryan K's Avatar
I know how to trick it into working... I'd rather it work without having to trick it. If you look, all of the pictures I put in that thread all but the last one have been photoshopped.
Right now, there are two "items" that modify the one "main" table. The Timing vs. RPM is your "main table". And then there is "MAP vs. Timing Adder". This table currently only ADDs to the main table. This works great for NA cars because you are only adding timing with vacuum. But if you want to work it out on a FI car what you have to do is "Offset" the main table.
For example, If you want to be able to subract 10 degrees of timing as you raise boost, you'll actually have to lowwer your Main table by 10 degrees across the board. It WORKs but its not intuitive. I am just saying that it could be MUCH better.
The last thing that modifies the main table is the SW retard. When 12 is applied to the input, the main table is reduced by the programmed amount. Again, you can trick it into adding timing by again shifting the main table down by the desired amount.
The real problem that you start running into is that the main table has a minimum number of Zero. Thus limiting the amount by which you can keep dropping the main table.
Ryan K.
Old Jun 28, 2006 | 10:33 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Subscribing.
Old Jun 29, 2006 | 03:31 PM
98turbls1's Avatar
ttt...any news??
