Belt Is Impossible To Get On????
Wrong Size. "bob @ Epp" I Could Really Use Your Help. I Am Getting Really Discouraged With This Kit. If Procharger Installed An
Adjustable Tensioner Pulley Then Why Don't They Make The Belt A Little Bigger So We Can Use The Tensioner. If Anyone Else Has The Same Problem Or And Solutions Please Let Me Know....thanks.
P.s. I Tried To Find A Larger Belt But They Don't Make One, I Would Have To Get It Custom Made....thanks.
i too would like info to the correct belt part number for my setup. and i just got the kit. i dont think i should have to be the one to cover for the correct belt
https://ls1tech.com/forums/forced-induction/532268-ati-procharger-belt-question.html
My last belt was a 25-080400 (400) with a 7-5/8 crank pulley and it worked with either a 3.4 or 3.7 blower pulley. If that will help with size issues.
Chris
If this helps.. Might have to measure what you need and try and plug in differant sizes on there web site to see what falls in the range.
http://napaonline.com/MasterPages/NO...t+-+Serpentine
Working with the Best Combo on my custom Spring 8 rib setup I made..
I've gone with these belts sizes..
25-080384
25-080392
25-080400
25-080408
25-080415
These part numbers are all correct above through Napa.. Car Quest uses a K instead of a 25 so it would be
K-080384
K-080392
K-080400
K-080408
K-080415
And so on...
Each belt is about a .75" difference. I'm running a 25-080392 with my custom 8" Crank and custom 3.2" Blower pulley. Spinning the hell out of my blower..
Good luck..
CLint
Right Chris (618Hawk)????
