New cometic gas filled head gaskets.
Old Jul 3, 2006 | 10:45 PM
LASTLS1's Avatar
6 Second Club Moderator
Default New cometic gas filled head gaskets.
Has anyone else used these for FI? If so have they worked for you?
Old Jul 4, 2006 | 12:26 AM
SuperZ's Avatar
Ive herd many things.Hopefully someone will chime in that has used em
Old Jul 4, 2006 | 07:37 AM
BlwnTA's Avatar
7 Second Club
I understand that they will be put to the test at a very reputable shop soon.
Old Jul 4, 2006 | 07:51 AM
sr71's Avatar
I have a set in my possession. I'll put up a new thread with pics later today.
Old Jul 4, 2006 | 07:55 AM
LASTLS1's Avatar
Well I used them on a 4.00" bore, the gaskets only come in a larger size 4.135? . To make it short and sweet I blew 7 cylinders on the dyno. The tune was on. The plugs looked great! Also I was using C16! I think there is too much of a gap between the bore and the gasket. LME said they didn't like the idea, I think they were right. ALL seven of those orings were destroyed!!! They all blew in between the cylinders, where it is SOOOO thin.
I would think twice about using them. I going to try the GM MLS gaskets.
Old Jul 4, 2006 | 11:10 AM
TwnTrboCE's Avatar
Man that sucks. I love the GM MLS gaskets. For now I won't run anything else. There cheap and take a beating. Using them on my new motor as well. Good luck.
Old Jul 4, 2006 | 11:59 AM
sr71's Avatar
actually they come in 2 sizes. 4.015 and 4.1xx. mine are 4.015".
Old Jul 6, 2006 | 08:49 PM
ThaLS1KidII's Avatar
We are about to put them on a 427 ls7 motor. I do know those things are some coin!
Old Jul 7, 2006 | 01:00 PM
LASTLS1's Avatar
These failed after about 8 dyno runs. I wouldn't use them again if they were FREE!
Old Jul 7, 2006 | 01:18 PM
FANTAZ28's Avatar
Moderator
maybe you should've kept the boost below 50psi!!
