Sts - Wrapped Exhaust -- Inside!!!!!
You can tell a little from this pic.
on the lift to the right!
Back when I was running a front mount turbo on my truck, I went to Lowes and got some B-B-Q Grill paint.
I painted the headers, then I wrapped the headers with the 2" wide fiberglass wrap, then coated the wrap with the B-B-Q grille paint. When you first crank up the vehicle, it'll smoke and stink for a little bit, but then it'll burn (cure) and then you're ok.
Made a huge difference in under hood temps.
I'd think that you'd want to "y" the 2 exhaust's together as quickly as possible under with about 2 1/4 to 2 1/2 tubbing into a single 2 1/2 to 3" tubbing to the turbo to keep up the velocity and pressure going to the turbo. The faster you merge the 2, the more heat you retain and less surface area for the heat to escape. That's ALOT of wind and air moving across those exhaust pipes to exchange heat. Just think, it's just as much air moving across the exhaust as it is moving across that inlet charge pipe which STS uses as an "intercooling" point.
Another thing I wondered about spooling: The outlet on my MP-T70 was 2 1/2", but all my charge piping was 3", and i used a reducer from the intercooler piping to the turbo. I always wondered on the remote mounts, would it be benifical to run the 2 1/2 or 2 1/4 tubbing from the turbo all the way to the engine, (less space to boost).
As far as changing the T70, just get a smaller A/R on the turbine if you can find one.
I'm building my car now around the thoughts of adding a remote mount T-70 to my car in the future!
Just a thought, and keep the research on the remote set-ups going.
D Moss
Air velocities in the piping should not exceed 200 ft/sec to keep pressure drop down. Even with my 3" piping, I'm getting something like 220 ft/sec between the compressor and the intercooler.
Mike
Originally Posted by mattslightning
The reason it helps is because hot air is more dense they say.
Might wanna just stick to saying it works and not try to explain it
Cold air = denser, Hot air = more energy, but I meant what you knew...
MLE
colder air is more dense = more power
its cool man, i was in the same boat a while back
looks like my summer project just got added....
wrapping the exhaust.
so just go to advance and buy 2 2x50' rolls?
