Sts - Wrapped Exhaust -- Inside!!!!!
I would definitely do number two... If your turbo is anywhere in the vicinity of the radiator like mine, the blanket really works... I never see temps above 210, even after some severe beatings:
2 things though :
1. They dont make a turbo blanket from what I understand that fits a GT55 yet.
2. I dont even know if it would fit as I hear they are pretty thick, so Im not sure if theres enough clearence for one.
Would wrapping the downpipe and headers be a signifigant help with my warm engine temp problem, or just mainly the turbo being controlled?
Second, you wrap header wrap on top of the 1st layer - not too tight, just snug. You don't want to fully compress the ceramic batting as it cuts down on its insulative properties. If you wrap from the rear to the front the wrap will last a lot longer because the leading edge is not exposed to the airstream:
I used Thermo-Tec 50'x2" rolls on the pipes and mufflers. It took 1 roll for each side. My LT headers are Jet-Hot coated so the cannot be wrapped after coating - it burns off then rusts bad.
Use good quality hose clamps, not those cheap Chinese crap things. Or you can use the Thermo-Tec Snap Straps, but IMO they are too $$$.
Save the scraps of header wrap and ceramic batting because they come in handy for insulating small things.
Here's the link for the Longacre Batting: http://www.longacreracing.com/catalo...id=127&catid=4
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
As long as his car is tuned, he will pass emissions. I passed in Lancaster County and passed easy with a P1SC, 38# injectors, long tubes, no cats and a dynomax bullet muffler FYI.
That is interesting about going under the axle, do you flange it on each end?
Chris
