Sts - Wrapped Exhaust -- Inside!!!!!
Looks like the premiere test is maybe 01/02 manifolds with ceramic coating, header wrap, ceramic batting, and then sprayed to lock the moisture. (correct in that order?) Talk about heat retention!
Ti is suppose to be the best but its not cheap and really hard to weld...
Just a thought
Generation II Copper Header Wrap improves heat resistance up to 30% more than current technology, by utilizing a new proprietary coating developed by Thermo-Tec; improved Thermal-Conduction-Technology (T-C-T).
Generation II Copper Exhaust Wrap creates more horsepower and reduces under-hood temperatures, increases exhaust scavenging, withstands continuous heat up to 2000ºF, contains no asbestos.
Generation II Copper Exhaust Wrap is sold in one or two inch wide, 50 foot rolls with a low profile 1/16" thickness.
The flexible clamp on pipe heat shield blocks over 98% of the damaging radiant heat of the exhaust.The High-tech composite construction of the heat shield provides the ultimate in protection.
The kits come complete with all clamps and install in minutes.
Clamp-on pipe heat shields are available in one, two and three foot lengths. Clamp-on pipe heat shields incorporate Thermo-Tec's proprietary coating technology developed by Thermo-Tec, Thermal Conduction Technology
Yeah so it should go like this white powder coat on the outside+ ceramic coating+ header warp
yes, i have 100 $ in just having the wrap kit sent to me.! its always 100 $ here, 100$ there!!!
Mike
Mike
I experience this while I drive. The harder I drive it, the faster is gets. It's definatley noticable on the old butt dyno.
I've seen this effect at the track too with rear mounts. The wrap would eliminate the need to drive the hell out it to get some decent times/numbers IMO. I think every turbo guy (front or rear mount) here knows that when their car is cold and they accelerate for the first time in the morning it doesn't feel as strong as when all the tubing is warmed up.
