Just got off the W2W Engine Dyno and....
Old Jul 13, 2006 | 09:44 PM
  #101
LASTLS1's Avatar
6 Second Club Moderator
Originally Posted by Reckless
Here are the numbers Tom:
Great results! Two questions. 1. How far have you pushed stock GM MLS gaskets? 2. On a set up like mine, how much hp is lost through the drive line? I know the converter makes a big difference. It feels too loose, but I'm going to try it a the track first. Andy.
Old Jul 13, 2006 | 09:51 PM
  #102
427's Avatar
427
Running on track Tom will probably shift between 82-8500rpm with this engine. I need to exceed the high data point by 2-300 rpm to get clean pulls. Doing this kills valvesprings quickly if you want data to 8500, so for tuning we try to stop once the torque rolls over. If the head gaskets would have held, I'm sure a 8000rpm run would have been done.
Kurt
Originally Posted by LTLHOMER
Is it going to spin more than 7500 on the track? Torque was still barely falling off at that point figured you'd want her up even higher.
Badass motor though for sure.
Old Jul 13, 2006 | 09:54 PM
  #103
LTLHOMER's Avatar
Kurt
Thanks for the explanation...
Congrats on building a badass weapon!
Now if you can only convince Tom to let ya get behind the wheel.
Oh yeah what does '3 turns in gate' stand for?
Old Jul 13, 2006 | 10:00 PM
  #104
427's Avatar
427
That is my note on the air regulator that is hooked to the top of the gate. That run had 3 turns to produce that boost.
Kurt
Old Jul 13, 2006 | 10:07 PM
  #105
427's Avatar
427
We have seen the same sort of numbers with a big block chevy with the standard Cometic gaskets. We had them hold up to 2700hp with a aftermarket aluminum head/block combo. The LS engine with aftermarket heads and factory block did not hold for repeated runs, although this was the nitrogen ring Cometics instead of the standard MLS. We will send them back and see what the Cometic guys think caused the failure.
Kurt
Originally Posted by 8seclt1
im really surprised at this statement as John Gullet's pro5.0 motor made over 2200hp and has run 6.30s @ 220+... he runs cometics without a problem... same with a number of Pro 5.0 and Outlaw guys..
Old Jul 13, 2006 | 10:10 PM
  #106
427's Avatar
427
1.The MLS is a great gasket, but we have never been above 1200 with reliable results.
2. Not sure of your losses, but we have seen as high as 25% with loose converters. Loose converters are easy to drive, they make boost quickly.
Kurt
Old Jul 14, 2006 | 06:33 AM
  #107
matt346ls1's Avatar
Great job W2W. I think a large number of people are starting to realize that you can pay a little more the 1st time at W2W and actually save $$ in the long run with a quality piece that will last and people that will stand behind a product. In my opinion W2W= Best in the LS1 business.
Matt
Old Jul 14, 2006 | 07:01 AM
  #108
MIGHTYMOUSE's Avatar
hope to check it out during my visit next week to find out what it takes.
great job.
Old Jul 14, 2006 | 07:44 AM
  #109
Reckless's Avatar
Super Moderator
Matt
Note to self..... add Matt to my "Wise Man's List"
Old Jul 14, 2006 | 11:17 PM
  #110
Uthinkso's Avatar
Next is o-ring, receiver groove, and copper head gaskets. I will post numbers tonight.
Did you cut the groove in the head and run a gasket with integrated o-ring? Curious of the set-up.
Old Jul 15, 2006 | 03:06 PM
  #111
sr71bbjr's Avatar
Doing that would be worthless..You cut a groove on one surface (the head)and the o'ring is pressed into the other (meaning the block)..
Old Jul 15, 2006 | 04:28 PM
  #112
Boostaholic's Avatar
I made a visual graph of the W2W dyno data.
Old Jul 15, 2006 | 07:14 PM
  #113
FSTR-THANU's Avatar
Outlaw 10.5 Director
Nice!
Old Jul 15, 2006 | 07:51 PM
  #114
moregrip's Avatar
what a rush!
WoW! Awesome #'s
Old Jul 15, 2006 | 09:14 PM
  #115
Reckless's Avatar
Super Moderator
Cool graph!
Old Jul 15, 2006 | 10:04 PM
  #116
thx - if you want the program to generate the graphs I could package it up pretty easy, all you have to do is type in the data for each data point.
Old Jul 15, 2006 | 10:23 PM
  #117
Brady's Avatar
LS1Tech Sponsor
or copy/paste into MS Excel Cool graph though!
Great power. Great job everyone..
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
