Twin turbo alt. relocation probs.
Old Jul 11, 2006 | 12:33 PM
BLWNZ's Avatar
Default Twin turbo alt. relocation probs.
I bought this from a user a while back and am just now at the point of installing it. I think it is supposed to be the kit from stainless works not sure though. Doesnt seem to fit right, I think the tensioner is not in the right place the belt hits the thermostat housing. Let me know what you think.
Old Jul 11, 2006 | 12:34 PM
bboyferal's Avatar
fix the pic
Old Jul 11, 2006 | 12:37 PM
smokinHawk's Avatar
there you go
tensioner is definatly to far out
Old Jul 11, 2006 | 02:23 PM
xssive's Avatar
That is the correct placement, you just need to add the extra idler pulley in that bottom right hole that you have empty now. The belt will then go up over the alternator pulley, down around the tensioner, up over the idler pulley, and then back down to the crank.
Old Jul 11, 2006 | 02:28 PM
RW99's Avatar
subscribing...
Old Jul 11, 2006 | 02:33 PM
tt427ls1's Avatar
LS1TECH Sponsor
Check out the pic with my beautiful drawing. You will have to weld a stub on there for the idle puller. After you do that, then swtich the pullies themselves around. Put the smooth on the tensioner and vice versa.
Old Jul 11, 2006 | 05:18 PM
BLWNZ's Avatar
I got it finished I think. I didnt switch the pulleys. My tensioner is ribbed and idler pulley was smooth so i think i will leave them how they are. Everything look ok? Runs really smooth and seems to be straight.
Old Jul 11, 2006 | 05:21 PM
RW99's Avatar
Looks good to me. Did you have to use any washers, crowbars, etc. to obtain correct alignment of the pulleys?
Old Jul 11, 2006 | 05:23 PM
tt427ls1's Avatar
LS1TECH Sponsor
Sweet , Glad to hear. I think I might of made that one awhile ago. Could be wrong though.
Old Jul 11, 2006 | 05:49 PM
BLWNZ's Avatar
i did have to use a couple but not many on the bracket to the head. Really worked out good thought it was going to be a bitch. Now all i have to do is the intercooler plumbing and im done... Thanks for all of the help.
Old Jul 11, 2006 | 09:46 PM
xssive's Avatar
Glad it worked out for you. I sold that to you a LONG time ago...
