ProCharger inlet help...
We did it on the dyno in a clean enviornment. I would never do that on the streets. If the green HKS mashrom picks up half of what the no filter setup picked im a happy camper. HKS is coming out with a new yellow one that works even better.
1/4 mile gains are average power gains, not peak usually. Up to 6400rpm the inlet on or off didnt make that much difference, after that the boost climbs quicker without it. The car doesnt spend a whole lot of time above 6500 but with the new cam I have in it it does so it may make a bigger difference. Most tracks I go to have a lot of gravel so I dont like to pull the inlet off, I'll have to make a screen one of these days.
I would be real carefull what I put in front of that blower, if that cobra thing is hard plastic it would probably be OK but if its rubberish forget it.
The ATI blower hat is hogging quite a bit of power. I would ditch it for a 90deg aluminum bend to a huge filter like that. We gained i belive 2psi of boost and about 40rwhp.
You must know how much hp gain you get with the hat off You'll probly be near the 8's
Could be several reasons why it doesnt pick up that much, most likely the average power gain for the rpm range I am running in, 6000-7000, just isnt that much, other is the heat from the radiator with it off. I did try a 90 degree elbow with no filter and it was about the same as the ATI hat so I ended my experiments there. I need an F1 or a 75 shot to get in the 8s I figure
Could you please pm me or post up some info who carries this...THANKS!!
I looked at using the K&N RX-4140 w/ XSTREAM top and then running duct hose to the XSTREAM top end of the filter...
you would have air intake short range to the head unit and cooler air being ducted in thru the XSTREAM top filtered end...
vs. having to pull all of the air thru a filter then an extended length of hose or tubing w/ bends before reaching the head unit...
