Filterin' the F1...
Old Jul 15, 2006 | 08:29 AM
DJ's Z's Avatar
Default Filterin' the F1...
Okay guys need some help here. The big *** K&N I've been trying to run I decided to start over for a few reasons. I don't think the IC is seeing enough clean air, without choppin' up the front any more than I have too, and the duct work I had running to it I didn't feel comfortable with.
So I need some info on what filters most of the ProCharger guys are running. If you give me a part number/site/store that would be a huge help.
I guess the biggest concern is finding one that wont colapse under full boost. The other of course is how much room I have to play with. It has to be a 4" opening and around 10-12 inches long or shorter if it will flow enough at 18lbs...any help??
Old Jul 15, 2006 | 11:14 AM
frcefed98's Avatar
S&B filters, the one on KP's car fits the bill, It has a 4inch opening and is the about 12 inches long. They make tons of different filters and the pricing is decent. I've had S&B filters on a few things and they are great and you can clean em like a K&N.
Kp's ATI kit was my old kit....so thats the reason I know what filter is on there
http://www.sbfilters.com/product_display.php?id=1972
www.sbfilters.com
J
Old Jul 15, 2006 | 11:59 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I use this one, but it has a 3.5 opening: http://www.knfilters.com/search/prod...x?Prod=RF-1004
I found this one which is similar to mine with a 4 inch opening: http://www.knfilters.com/search/prod...x?Prod=RE-0860
All I did was fabricate a bracket to hold it in place in the stock ATI location.
Old Jul 15, 2006 | 02:18 PM
BlkHwk's Avatar
Interested in how that cobra elbow works out for ya.
Old Jul 15, 2006 | 02:26 PM
DJ's Z's Avatar
Thanks for the info guys...I'll be checkin' it out.
No go on the Cobra elbow. It's rubber...If it was a hard ABS type plastic I'd give try. So...money wasted. I have a close friend thats going to try and make the same type of elbow but in aluminum...I'll give that a try if it clears everything.
Old Jul 15, 2006 | 02:46 PM
BlkHwk's Avatar
Thanks for the info. I was thinkin the same thing about fabbing one out of alum. I may give it a try when the time comes.
Old Jul 15, 2006 | 05:06 PM
TS6's Avatar
TS6
I wonder if a carb hat for a blow-through setup could be used? I realize the opening is too big at 5" or so, but I bet if you called one of the companies that sell them they could just cut it at 4" instead. Then it would go to a 3" or 4" tube, depending on which one you get. They are pretty low profile for clearance.
Old Jul 15, 2006 | 07:02 PM
kp's Avatar
kp
www.sbfilters.com
J
This filter here is the one you are talking about? The smaller filter you gave me that was used I never puton the car, this one was new in the box when you sent it and I could have swore it was a K&N..
This one has a 4" opening and went right on the 4" 90 degree elsbow I tried..
Old Jul 15, 2006 | 07:32 PM
frcefed98's Avatar
Nope both filters I sent were S&B, always had good luck with those filters.
One was a blue top S&B, and the other was the new one with the metal reducing base(pictured)
J
Old Jul 15, 2006 | 07:38 PM
kp's Avatar
kp
I just assumed it was a K&N, I guess I should clean it one of these days, been over a year
Old Jul 15, 2006 | 07:48 PM
frcefed98's Avatar
Old Jul 15, 2006 | 09:01 PM
Superado's Avatar
11 Second Truck Club
AEM DryFlow 21-2059DK...4" ID x9" Conical...personal choice...
Accel Kool Blue KUC 1004...4"ID x 12" Conical
Old Jul 16, 2006 | 12:24 AM
Cyborg's Avatar
Another vote for the AEM Dryflow. Oiled filters channel dust and cause elevated dirt ingress. If you doubt this, go and get an engine-oil analysis before & after running an oiled filter and see for yourself. (obviously change the engine oil between samples)
Old Jul 16, 2006 | 09:28 AM
DJ's Z's Avatar
I'll be checking them out...Thanks!!
