Another PCV questions (pics)
there are 57 different PCV threads. Ill draw a quick pic in a few.
Very crude drawings... Art isnt a strong point
These are what Im doing. Probably the second one. On the second one, you wont need a can on the valvecover to intake line because itll only see vacume at part throttle or idle and as soon as boost is entered, the check valve will close.
You knocking my mad drawing skills
Yeah, its a lot easier to understand something when is in a picture. I imaging that you dont need the filer on the drivers side, but itll allow a way out if you cant create enough vacuum and the case starts to build pressure.
It worked fine and the exhaust damn sure caused a vacuum to help pull it out...
Even if you still had cats and/or rear o2's, you could tap beyond them...but I don't think that applies to most of you guys...
