Post pics of where your FI Guages are located
Old Jul 19, 2006 | 09:44 PM
Superman09's Avatar
LS1Tech Sponsor
Default Post pics of where your FI Guages are located
Just like the title says... where do you have guages mounted. I cant decide to go pillar or AC vents. Both have their ups and downs...
pillar, easy to see, just look a little left, but everyone can see it, at night they light up and people see it and it just screams I have a power adder!
vents- cant be seen by anyone, fit like their molded, but they are a little harder to keep track of.
Post pics of where yours are and why you like them there and your opinion on what you think.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jul 19, 2006 | 09:51 PM
White.Lightning's Avatar
Being you have a T/A, vents are the best option. I had a triple pillar, kinda looked weird and gave you a slight blind spot. All T/A's that I have seen with gauges in their vents look awesome IMHO.
+1 for vent location......you should've made this a pole
Andy
Old Jul 19, 2006 | 09:58 PM
Superman09's Avatar
LS1Tech Sponsor
Any mod, could you make this a simple poll, 2 choices for TA, pillar or ac vents. Thanks!
__________________
Old Jul 19, 2006 | 10:02 PM
2002ws-6's Avatar
I'f your your over 6' the piller pod only works with two guages. I'm 6'3" and have a triple pillar pod and can't se my wideband o2 sensor, its the middle gauge, it does have data loggin' thou. Gotta ride with a friend to see if i'm still 10.5:1 at 8psi
Old Jul 19, 2006 | 10:10 PM
2002ws-6's Avatar
forgot to add last time i got pulled over the cop didn't even see the a pillar pod he was too pissed off 70 in a 30 sunday at noon. that cost $400.00
Old Jul 19, 2006 | 11:17 PM
Mike 01WS6's Avatar
I'm about 5'11" and tend to sit more upright when I'm driving my car (ie....i don't lean way back gangsta style......). I like to have my arms bent at the elbows and up towards the wheel in a much more attentive manner.....this position seems to block the middle guage a little bit. I always keep the A/F at the top pod (so it is always in view)...fuel in the middle (sometimes can't see the very top of the guage where the needle lies....but I don't look at it much anyways), and boost at the bottom pod.
Old Jul 20, 2006 | 12:47 AM
Jimmy P's Avatar
I'm about 5'11 and have no problem with the pillar pod.
Old Jul 20, 2006 | 08:22 AM
Superman09's Avatar
LS1Tech Sponsor
Ok, so i've searched some as well and found that in triple pods, some of the guages are blocked, so really they arent that easily seen. I'm leaning towards the vents, anyone have any good pics of TAs with guages in the vents? Thanks!
__________________
Old Jul 20, 2006 | 08:32 AM
Frost's Avatar
Didn't you just make this thread (or one just like it?) a week or so ago? https://ls1tech.com/forums/appearance-detailing/535452-guage-mounting.html
Old Jul 20, 2006 | 08:46 AM
Superman09's Avatar
LS1Tech Sponsor
This one i would like to see some pics, other one was to see what most people used, got a few pictures but would like to see some more options. Yea its kind of close but the topic is still on my mind and that thread died so i figured i'd make one more dominated to pictures
__________________
Old Jul 20, 2006 | 08:47 AM
Superman09's Avatar
LS1Tech Sponsor
BTW, i like your set up frost... a combo, can see the 2 in the pod well and the other in the vent, good thinking!
__________________
Old Jul 20, 2006 | 08:53 AM
Country Boy's Avatar
Senior Member
Old Jul 20, 2006 | 08:57 AM
bowtieman81's Avatar
Do you have problems seeing your fuel pressure with the triple pod Carl? I was thinking about the triple with the guages oriented just as you have it.
Old Jul 20, 2006 | 09:01 AM
Senior Member
Nah, no problems when I sit in the car. Of coarse... its not running yet
Old Jul 20, 2006 | 09:08 AM
Superman09's Avatar
LS1Tech Sponsor
People with guages in vents... do you block off the vent at all? also where do you run the lines? Thanks
__________________
Old Jul 20, 2006 | 09:31 AM
Senior Member
All the ones Ive seen, take up the entire vent so its useless.
Old Jul 20, 2006 | 09:41 AM
Frost's Avatar
Block the vent off really well.... AC will cause condensation in the high dollar boost controller if the cold air can get to it.
Old Jul 20, 2006 | 09:53 AM
Superman09's Avatar
LS1Tech Sponsor
ok thanks, what do you use to block it off?
__________________
Old Jul 20, 2006 | 10:17 AM
Boostaholic's Avatar
my car has a hvac delete done
Old Jul 20, 2006 | 10:20 AM
CP05GMC's Avatar
Vents:
CP
