Final Tune/Dyno done...
Old Jul 21, 2006 | 02:02 PM
DJ's Z's Avatar
Default Final Tune/Dyno done...
Well finally stuck it on the rollers at Conley's Performance here in Houston to see where the final tune needed to be and get some numbers. On the Mustang Dyno: 781RWHP / 720RWTQ. What we liked about it was the perfectly flat (781 HP) line from around 6000 to 7300rpms...Not exacty sure what it would be on a Dynojet Dyno. I've read 10-12% higher.
Heres a link to some of the pulls...
http://media.putfile.com/Dyno-Pulls
"Special Thanks" of course goes to Mike (IconAutoSports) for your time and patience through all of this and helping me put together a pretty nasty ride...
Joe (G&G Performance Engines) for building a bad *** LS2, Lonnie (Lonnies Performance) for a great fuel set up that many thought wouldn't be enough, Nate (Nasty Performance) for all the other needed fuel goodies, Bob EPP (Exotic Perfromance Plus) for the FMIC and piping kit, great looking/fitting kit, Eric (ESR) for your time and a great tuning and last but not least my wife for putting up with all my ****!! Great job to everyone involved... "THANKS"!!!!!!!
Old Jul 21, 2006 | 02:48 PM
kp's Avatar
kp
Very nice, what did you end up doing for an inlet?
Old Jul 21, 2006 | 03:01 PM
2002/Black/SS's Avatar
u dont have the nitrous anymore?
Old Jul 21, 2006 | 03:20 PM
RyanJ's Avatar
SSU Moderator
Is it really good that the HP is flat from 5000+, or are you showing a limitation somewhere (blower, airflow, etc.)? You'd think the goal is to have a constant rise in HP until peak. ??
Old Jul 21, 2006 | 03:33 PM
MiaSSmaro98's Avatar
awesome congrats
Old Jul 21, 2006 | 03:52 PM
Firehawk853's Avatar
What are you using for injectors / fuel system?
Old Jul 21, 2006 | 04:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice... hittin' the track soon?
Old Jul 21, 2006 | 04:10 PM
Tiago's Avatar
Congrats Dennis! that curve is sick!!! the car hits hard...noone will keep up with you next week
Old Jul 21, 2006 | 04:49 PM
NA$TY-TA's Avatar
What size cubes and turbo size again???
Kyle
Old Jul 21, 2006 | 04:57 PM
Tiago's Avatar
Kyle
he has a 408 with a F1 procharger... it hit really hard!!!!
Old Jul 21, 2006 | 05:01 PM
Nine Ball's Avatar
LS1Tech Co-Founder
It was impressive, I was there to watch the pulls. That thing wants to launch off the dyno rollers. Keep in mind that these pulls were done thru a full exhaust with a muffler, they had to close the cutout to get a good reading on the wideband O2. I wonder how much the cutout would be worth?
Old Jul 21, 2006 | 06:11 PM
lcvette's Avatar
once you reach peak boost, the curve will follow the flow characteristics of the heads for the boost pressure and the curves will look more like a naturally aspirated engine. if you were to see a continuous rise, you would not have reached peak boost yet and the turbo is still building higher pressure over the rpm rang much like a blower car does. the key to turbochargers aside from being more efficient then blowers is the fact that they reach their peak boost much sooner and give you a lot more area under the curve of usable power and torque to drive with.
nice numbers man!! looking forward to the track results!
Chris
Old Jul 21, 2006 | 06:24 PM
black98ws6ta's Avatar
Chris
Umm, its procharged right?
Old Jul 21, 2006 | 07:04 PM
SSilverSSurfer's Avatar
correct-F1 to be exact, with a 408 LS2
Old Jul 21, 2006 | 08:27 PM
DJ's Z's Avatar
KP this is what I'm doing temporarily...having something built similar to the Cobra Hat but in aluminum to a 4" short tube and AEM Dry Filter...
Old Jul 21, 2006 | 08:28 PM
DJ's Z's Avatar
Nope...F1 w/ 408 LS2 on pump (93) gas...
Old Jul 21, 2006 | 08:31 PM
DJ's Z's Avatar
RC 75# / Dual intank 340 Walbro / Aeroquip -6an feed / Stock feed for return / Aeromotive FPR / Base FP at 58#'s boost ref
Old Jul 21, 2006 | 08:37 PM
CAT3's Avatar
Restricted User
Sweet. I need to check out the links and get some looks at the mounting etc. That sounds like a damn solid setup.
Old Jul 21, 2006 | 09:14 PM
kp's Avatar
kp
Works obviously, I may try that, looks like a pasta strainer or something.
Aluminum cobra type thing would be nice..
Old Jul 21, 2006 | 09:52 PM
EPP's Avatar
EPP
Dennis, I'm glad to see you're getting great numbers! Congrats! Bob
