ATTN: Kyle Farley.....
Damn man..... it really had be thinking after it happened.....
I have the best bad luck i know of...
I had planned for the car to sit that night and then fo to MIR and race the next day......... Man that would of been mad at 100+ MPH
Kyle
Way more gear choices and easier to swap gears..BTW I have gone 8s in a 3500lb car with 7/16 wheel studs - ripped the axle tubes out of the housing (stock 12 bolt housing) before the studs broke. Like I said, torque wrench and check them often
Yeah ill be doing that very often..... even more so since i really do drive it on the street alot........
Not looking forward to smelly *** gear oil here tomorrow....
Im off to bed............
Kyle
Like Harlan stated that last pass had 155 or so in it.... bouncing off the rev lim the last 150ft or so....... and thats at 20 psi.
Harlan and JZ seam to think this turbo is good for 6 or so psi more.....
Only one way to find out..... It is rated at 1575hp........not like thgat really means much
Ill be pulling the axles tomorrow..... this really has me thinking.... i know i need to learn how to really control the car as it sits now but why take the cover off later..... should i do the gears now..... thats what im thinking to myself...... plus it will be even more stret friendly even with no overdrive.
Kyle
FWIW...I lost over 6 mph at the same boost but the DA was different by 3500. IATS were up like 50 degrees. The ET was close but that was more due to the track than anything else.
Nope on both questions like Derty said..... running a 28" tire.....
Maybe one day...
Kyle
Kyle
i may try to get the rest of the season out of them, cuz i think a 9" is in my near future
Like mine...
To replicate mt setup exactly would be alot more then what we spent......
Stenod gave me a HUGE break.....
if you have nothing now.....
figure about $10K for the turbo kit
about $8k in drivetrain
another $10K in the motor
plus suspension and fuel and tuning....
With labor and misc little stuff your prob looking at $40K to duplicate it......
and thats doing alot of it your self.
Your best bet is to call Stenod and ask him.
Kyle
