ATTN: Kyle Farley.....
Old Aug 8, 2006 | 05:32 AM
  #201
NA$TY-TA's Avatar
3.73's in there now.
Kyle
Old Aug 8, 2006 | 08:30 AM
  #202
TurboGibbs's Avatar
Your car is one more to add to the list that I have seen break axles, rears, tranny's and wheel studs etc. when they swap to MT DR's from slicks or DOT slicks. Those tires bite hard and don't wrinkle as much and cushion the blow like bias ply's do. They often cut quicker 60's as well.
Glad you guys and the car are ok. Another 5 mph faster and your quarter panel may be re-shapped
Old Aug 10, 2006 | 04:53 PM
  #203
Andy02Z's Avatar
Default Turbo
So how much does the turbo have left in it after the 150mph pass?
Nice car btw, I have been watching this for a while now. Any more videos yet?
Andy
Old Aug 10, 2006 | 04:55 PM
  #204
DrTurbo's Avatar
LS1TECH Sponsor
That car should trap 155-160 with the boost up higher and well into the 8's. Which should be around 1100-1200rwhp through that auto tranny.
Old Aug 10, 2006 | 04:57 PM
  #205
y2khawk's Avatar
It probably would have been 155 or damn close as it was. On the limiter most of the way past the first MPH light if not before it.
Old Aug 11, 2006 | 05:17 AM
  #206
NA$TY-TA's Avatar
So in your opinion what rear gears now Matt??
3.55's or 3.42's?????
Kyle
Old Aug 11, 2006 | 01:18 PM
  #207
LTLHOMER's Avatar
Kyle
12-bolt or 9 inch? If you have a spool and a 12-bolt, the lowest you can go is 3.73.
Old Aug 11, 2006 | 01:36 PM
  #208
y2khawk's Avatar
not true, I had a 3.55 in my 12bolt with a spool.
Pick a MPH target Kyle
Old Aug 11, 2006 | 01:45 PM
  #209
Fireball's Avatar
are you planning on running competition gears (the softer ones) or regular standard material? Its hard to find any listed in less than 3.90 ratios...matt...what did you run?
Old Aug 11, 2006 | 01:47 PM
  #210
LTLHOMER's Avatar
You must have had a 3 series carrier...most 12-bolts (especially mosers) come with 4-series carriers and there is not enough room for the pinion on anything lower than 3.73. You can switch to a 3-series and give it more room but that's more than just a simple gear swap at that point.
Do you know what carrier you have Kyle? I have a 4-series in mine which means 3.73 is as low as I can go...
Old Aug 11, 2006 | 02:03 PM
  #211
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
3.42
I had a 3.31 in one of my old Chevelles.
Old Aug 11, 2006 | 02:12 PM
  #212
LTLHOMER's Avatar
3.55
3.42
Were they spools? It's the carrier that makes the difference.
Old Aug 11, 2006 | 02:25 PM
  #213
LS1Tech Co-Founder
3 series posi
Old Aug 11, 2006 | 04:12 PM
  #214
NA$TY-TA's Avatar
Ok 165mph......
I thought it was a 3 series......
Kyle
Old Aug 11, 2006 | 04:24 PM
  #215
y2khawk's Avatar
Ok 165mph......
3.42 it is, little room to spare above 7krpm and tire growth.
Get to it!!!
Old Aug 11, 2006 | 04:26 PM
  #216
Noyzee's Avatar
8 second mod
Yeah to much... car doesnt know its own strength.......
I am glad it happened when i was at a stop light though......
man it would of been bad on the freeway.
Sheered all 5 ARP wheel studs off this afternoon....
Tow truck guy and my Buddy Chris and my wife really helped me out. car is home in the garage.
New axles with 5/8 studs have been ordered. Thanks for those Joe.
Only downside is the 2 week wait.
Thanks god i didnt wait and went with my original plan of taking the car to the track tomorrow.
Ill post a couple pic's tomorrow.
Kyle
congrats on the car first off.
2nd, i run those studs in my car. your making me want to change them!!!!!
how did that happen?
Old Aug 11, 2006 | 04:32 PM
  #217
LTLHOMER's Avatar
Ok 165mph......
Kyle
How much boost are you going to run? 35?
Old Aug 11, 2006 | 04:41 PM
  #218
Slow Z28's Avatar
WOW, that picture brings back memories. except this was AT the track. it really does make you think. launched and they all broke. thank god it wasn't 50 ft further. These were 7/16" ARP studs in the moser 9". Glad to see you are safe! I had my axles drilled out to fit 1/2" studs, but shoulda done the 5/8" like you guys. This was only a 460rwhp 6speed car. 6500 clutch dumps though
Old Aug 11, 2006 | 08:33 PM
  #219
NA$TY-TA's Avatar
Brad just from the power and launch's we guess...... car has only been to the track 3 times.... Id be leary of them if i were You. I know Harlan had to change them on his car when he was running 10.doh's back in the day.
Kyle
Old Aug 11, 2006 | 08:39 PM
  #220
NA$TY-TA's Avatar
What ever she will take.....
Like Harlan stated that last pass had 155 or so in it.... bouncing off the rev lim the last 150ft or so....... and thats at 20 psi.
Harlan and JZ seam to think this turbo is good for 6 or so psi more.....
Only one way to find out..... It is rated at 1575hp........not like thgat really means much
Ill be pulling the axles tomorrow..... this really has me thinking.... i know i need to learn how to really control the car as it sits now but why take the cover off later..... should i do the gears now..... thats what im thinking to myself...... plus it will be even more stret friendly even with no overdrive.
Kyle
