View Poll Results: what heads are you using
ETP
31
8.22%
AFR
72
19.10%
TEA
10
2.65%
DART
14
3.71%
Edelbrock
6
1.59%
TSP/PRC
11
2.92%
Stock 6.0
71
18.83%
Patriot Performance
38
10.08%
Stock 5.7
42
11.14%
Trickflow
10
2.65%
GTP
3
0.80%
Ported stock (by someone other than listed)
31
8.22%
OTHER (please list in post)
23
6.10%
AllPro
15
3.98%
Voters: 377. You may not vote on this poll
what heads are you using for your boosted application
Old Aug 13, 2006 | 11:48 PM
  #41
Darren P's Avatar
untouched stock 5.7 heads
ran 11.7 at 118 MPH with ~7PSI
475 RWHP @ 4900 RPM
560 RWTQ @ 3400 RPM
9 inch rear with 3.50 gear
Old Aug 14, 2006 | 10:26 AM
  #42
enginjoe's Avatar
Stock heads. 12.058 @ 120.28 with 2.0 60ft, 3772lbs. No dyno yet on high boost.
Old Aug 14, 2006 | 09:11 PM
  #43
fenix99's Avatar
Restricted User
stock for now....My friend is hand porting stock 6.0L heads but as of right now no tune/numbers/or track times...will update as i finish stuff...should be tuning 2morrow (5psi custom rear mount....stock motor, & a couple bolt ons) wish me luck
Old Aug 16, 2006 | 05:38 PM
  #44
2000 Tran Zam's Avatar
afr hand ported 205's by meaux racing.
13.5 lbs = 833 rwhp and 828 rwtq
FMS took it to the track, ran once and got kicked out.
11.6 @ 136 with a 2.0 short time
Old Aug 16, 2006 | 05:45 PM
  #45
chriswtx's Avatar
Stock 241 heads/stock bottom, 617rwhp/572rwtq at 10psi, best time 11.4 at 130mph on 19" street tires...
Old Aug 16, 2006 | 06:18 PM
  #46
PurEvl's Avatar
Originally Posted by Tiago
AFR 225s
same here, i had the 6.0l stage 2 patriots and blew the coolant plugs out BOOOOOOOOOO
Old Oct 2, 2006 | 08:16 PM
  #47
Earl H's Avatar
Out of the box AFR 225's...times and equipment in sig.
Old Oct 2, 2006 | 08:28 PM
  #48
Got Me SOM's Avatar
8 lbs-484 rear wheel with stock heads 11.0 @ 124 full weight on 17" drag radials
12 lbs-526 rear wheel stock heads with crane dual valve springs no new time yet
gettin retuned this weekend then we hit da track again.
debating on afr's or cheaping out with patriot 6.0 heads.
Old Oct 3, 2006 | 12:50 AM
  #49
longrange4u's Avatar
I thought you were selling your setup?
Old Oct 3, 2006 | 07:40 AM
  #50
Got Me SOM's Avatar
it is for sale for the right price, i'm not gonna give my car away. a lot of people are low balling me, i'll just keep the car and figure out something.
Old Oct 3, 2006 | 12:57 PM
  #51
Pray's Avatar
Unported 243's. It ran 11.01@130 at 5psi and 12* timing. About 525rwhp. At 6psi and 14.5* it put down 550/500. At 10psi 14.5* and below 10.0:1afr = 632/517. I am installing meth and am going to pulley down to run around 8psi. Should be around 600/550. I will get some more track times after that.
Brett
Old Oct 3, 2006 | 02:52 PM
  #52
trans2000am's Avatar
just got 317 6.0's getting ported soon.
Old Oct 9, 2006 | 02:04 PM
  #53
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I edited the poll, changed mine from 6.0 to AllPros.
My #'s:
-AllPro heads
-800rwhp
-up to 26psi
Old Oct 9, 2006 | 06:58 PM
  #54
JMBLOWNWS6's Avatar
6.0l heads hand ported 650 rwhp 11psi
Old Oct 11, 2006 | 11:36 AM
  #55
Superman09's Avatar
LS1Tech Sponsor
stock 6.0L heads are 317's correct? How much approx CR drop are you guys seeing switching to these over stock LS1 heads? Also whats the approx hp gain by getting them ported? Real necessary to have them ported? Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Oct 11, 2006 | 12:17 PM
  #56
LS2Camaro's Avatar
What about RHS(Racing Head Service)?? Any FI guys out there use these, recomend? Didnt see in poll.
Old Oct 16, 2006 | 07:33 PM
  #57
96 Comp T/A's Avatar
The RHS heads are rebadged ETP's.
Old Oct 16, 2006 | 08:28 PM
  #58
98turbls1's Avatar
You'll usually see around a .5 cr drop from stock 66 cc heads... It's not necessary but every little bit counts...
Old Oct 17, 2006 | 12:53 PM
  #59
RX-Ben's Avatar
Heads should go hand-in-hand with the intake - are people using the LS6 intake or the LSX/LS2 intake? How is the upper (6500+) rpm performance? If there is a gain w/and LSX-90 - is it really worth the extra price?
Also- what intake port sizing is adviseable? Supposing a stock 346- would a 205cc runner work better in an FI app than a 225? If so, where in the rpm range would it work better, and why?
Thanks
Ben
Old Oct 17, 2006 | 12:58 PM
  #60
I run a GMPP Single Plane converted to EFI with an Elbow and a 90mm throttle body installed. I mildly ported it to clean up the casting flash (which is a major undertaking because it needs a lot of work). I still left myself plenty of room to grow, but in order to do a proper job of porting you need to cut the intake manifold in half, port it and then weld it back together. That will be for the next go-around I am sure, it should breathe plenty well as is.
