Cutout on a restrictive exhaust on a high-hp turbo car
Old 08-03-2006, 08:14 PM
Turbo LS1 SS's Avatar
Default Cutout on a restrictive exhaust on a high-hp turbo car
heres the deal....i bought a magnaflow due to a good deal for the car this year. i knew it was going to be restrictive, and planned to use a cutout.
in true bench racing fashion, what kind of gains should i expect using a 3" cutout over the full exhaust on my setup at around 10-15psi...(setup in sig).... what kind of gains power wise, at the track, etc
thanks
Old 08-03-2006, 09:15 PM
engineermike's Avatar
First of all, the Magnaflow flows VERY well. I just switched from a 3.5" Aerochamber to a 3.5" Magnaflow and dropped backpressure from 48 psi down to 34 psi.
That brings me to my 2nd point. If you use an e-cutout and the muffler has some backpressure, the boost will rise - possibly alot. I have 2 severely blown head gaskets to prove it. I dropped the muffler and gained 6-8 psi boost.
Mike
Old 08-03-2006, 10:22 PM
2002/Black/SS's Avatar
hey turbo ls1 ss, i also plan on running a 3" electric cut out about 3 feet from the turbo on my hiflo downpipe. let me know how it goes for you, also i plan on tuning for the cutout being always open, so when its closed i can race slower cars (if it will work like that)
Old 08-04-2006, 06:27 AM
cablebandit's Avatar
good question. I have dual 2.5 cutouts in the y-pipe and use a stock catback. Seems to flow ok
Old 08-04-2006, 06:54 AM
TTSSZ's Avatar
Me too, duel 2.5's in the y.
You can feel the diff.
I think about 5% HP gain over my borla w. no cats.
Old 08-04-2006, 07:07 AM
smokinHawk's Avatar
on my tti kit i used a cutout and when i opened it it seemed i gained about 50-75hp
i could definatly tell.
Old 08-04-2006, 07:12 AM
good news......
i did some late research and it seems people are gaining 50-80rwhp....... which makes me warm and fuzzy inside ..... my guess was ~30-40.....so..this should be good. i defenitely notice my tailpipes are getting pushed out of allignment since ive been boosting....hehe
FYI....the magnaflow is advertised as a full 3" exhaust..when in fact, right at the beginning of the I-pipe, as with other sections, it is down to like 2.75" ID (maybe less), and the beginning of the tailpipes is like 2.5" OD, IF THAT, which is shitty. my buddy just switched from a true dual setup that was as small as 2.5" in some parts, with 1 3/4" headers, to KOOKS 2", and a 4" mufflex on his built procharger setup. that DEF free'd up some ponies.
Old 08-04-2006, 08:06 AM
bowtieman81's Avatar
Anyone actually had a dyno of an open versus closed cutout?
Old 08-04-2006, 12:55 PM
WestSide's Avatar
Will there be much of a difference if the cutout is farther down by the passenger seat?
Old 08-04-2006, 12:59 PM
My opinion is closer to the turbo is better, but I am not sure it would make a huge power difference to have it further downstream.
Old 08-04-2006, 01:09 PM
SUPER DAVES Z's Avatar
The closer the better!
Old 08-04-2006, 01:41 PM
PurEvl's Avatar
thanks
i have a restrictive exhaust myself with a cutout, i gained about 60hp/60tq with it open
Old 08-04-2006, 01:42 PM
PurEvl's Avatar
yep thats how i knew
Old 08-04-2006, 02:24 PM
Thanks. I like to have some real results to back up theories.
Old 08-04-2006, 03:44 PM
The problem is that it could be anywhere from 0 hp to 200 rwhp gain, depending on just how crappy your muffler is. Discard any results that don't have the exact same muffler and hp as you, and you don't have much left.
Old 08-04-2006, 03:49 PM
i just fixed my pre-turbo leaks....and noticed while a great improvement in power/spool/holding boost..im still loosing some boost on the top end...which has to be a result of wayyyy to much back pressure. its nice when u leave a 200ft tire mark from a 3rd gear pull at 3000rpms
Quick Reply: Cutout on a restrictive exhaust on a high-hp turbo car
