think my MAF crapped out
Old 08-06-2006, 06:17 PM
ss01layinwheel's Avatar
Default think my MAF crapped out
well I been havin problems with my a/f ration lately. instead of running at 11.2 a/f wide open it shoots to 15:1 or so. My MAF is reading 30 lbs a minute at about 3000 rpms then drops to -34 lbs at like 3200 all the way to -50 lbs at redline. how common is it for MAF's to crap out on LS1s?
Old 08-06-2006, 07:30 PM
Jake@EPP's Avatar
Check to see if there is dirt or oil in the maf. If there is take some carb cleaner and hose it down with it. Use a blow gun to dry it off. The maf will read horribly if it is dirty.
Old 08-06-2006, 11:59 PM
i cleaned it already...no change
Old 08-07-2006, 03:16 PM
any other thoughts from anyone?
Old 08-07-2006, 06:24 PM
Got Me SOM's Avatar
they crap out pretty easy. did you backfire by any chance? look inside and see if you busted one of the little wires.
Old 08-07-2006, 08:46 PM
xxxtreme36's Avatar
when i installed my paxton on my lt1 it backfired and now i have a MAF failure code.
Old 08-07-2006, 09:52 PM
Smearin's Avatar
Ever thought of going to Speed/ density?
Old 08-08-2006, 12:33 AM
xxxtreme36's Avatar
how do you go from a maf to speed density?
