Block selection
Old Aug 15, 2006 | 02:14 PM
Ari G's Avatar
Default Block selection
What Blocks are you using with those high hp
Can the aluminium stock block handle 1100hp or the truck Cast block?
Old Aug 15, 2006 | 04:03 PM
y2khawk's Avatar
yes and yes
Old Aug 15, 2006 | 04:33 PM
nitrorocket's Avatar
I run aluminum, 800+ rwhp.
Old Aug 15, 2006 | 07:58 PM
Ari G's Avatar
Say with the aluminium block,isin´t it easy to warp them if the mis heat?especially with high boost
Old Aug 15, 2006 | 08:47 PM
I run 18.5 psi in a street car with 93 octane, the car runs at 200 all the time, no problems here!!!
Old Aug 15, 2006 | 09:00 PM
cws T/A's Avatar
Ive never seen a crooked aluminum block .Aluminum doesn't bend it breaks. IF its bent its probably melted and cooled to that shape. I figure your refering to the stock cylinder sleeves Get some thicker sleeves DARTON has some like the ricer hondas do to make the block survive . Im thinking not many blow because off to much power, unless your John Force their will always be a culprit inproper tune.. leanspike .. not enough fuel retard at the wheel ...John Force etc.
