The beginning of something (TTi install)
Old Aug 17, 2006 | 10:27 AM
bowtieman81's Avatar
Originally Posted by CHRISPY
I would use the brake master for boost and not the TB port. Nice work on the kit man, you appear to be very thorough
Any reason for using the booster line over TB port? I was thinking maybe using the port would keep some oil away from the gauge line.
Thanks for the compliment!
Old Aug 17, 2006 | 09:54 PM
Default Progress/problems tonight
Well, went to bolt up the log turbo and DP to find out the dp was hitting my upper motor mount bolts. I have poly mounts with the nuts towards the outside of the mount. Apparently this is incompatible with the TTi dp
So, had to nearly remove the motor mount to get the top 3 bolts out. Cut some off the bolts, turned them around and put them back in. I guess this a lesson learned for anybody else with poly mounts who has this kit.
finished
turbo stuff bolted up
Then went to bolt crossover on and it won't fit.
https://ls1tech.com/forums/forced-induction/561130-wtf-need-crossover-help.html
Old Aug 24, 2006 | 09:19 AM
Figured I would update my progress over the past few days.
Since the jackass seller gave me a useless crossover, I had to make my own. It is basically done, just need to finish the welding on it. Also had to fix up 2 of the intercooler pipes. They also just need the finish welding done.
I will post up some pics of them later today.
Old Aug 24, 2006 | 09:49 AM
RealQuick's Avatar
Good to hear. It will be worth it when ts done.
Old Aug 24, 2006 | 11:52 AM
Billiumss's Avatar
That seller sure sounds like an azz, he'll get his one of these days...
Old Aug 24, 2006 | 07:14 PM
Well, here are some crossover pics before the finish welding. What you guys think? I know its not pretty, but I think it should work decent. Cost was about $47.
Also, anyone know what this litte mailbox shaped thing is? I had to relocate it because it was in the way of the intercooler pipe, but I dont know what it is.
Old Aug 25, 2006 | 09:01 AM
SUPER DAVES Z's Avatar
Looks good, just make sure it's as high against the trany as possible, because if it's not, you will drag it on anything and everything!!!
Old Aug 25, 2006 | 09:06 AM
It is just under the oil pan, right behind the factory k member. The clearance to the oil pan is about 1/4".
After running that darn QTP y pipe I have some confidence this crossover wont drag on stuff.
Old Aug 25, 2006 | 12:18 PM
MIGHTYMOUSE's Avatar
looks like it will be a problem for you, need to extend it out and under the transmission after the bellhousing.
also the tti website has an installation manual, you should use that...iremember relocating the cruise control, but not that vacuum canister thing.
Old Aug 25, 2006 | 12:33 PM
You really think it will be a problem? I modeled it after their most recent version of the crossover, shown here. I think smokin and stoleit have the crossover in a similar spot.
In my case I dont see extending it back past the bellhousing gaining me much, if anything in ground clearance.
I have the TTi instructions, but my cruise control box is not on the passenger side of the car where the instructions indicate it should be. Instead of have that mailbox looking thing. I guess the car's layout have changed year to year. Don't know which model year TTi did their instructions on.
Old Aug 25, 2006 | 12:34 PM
RealQuick's Avatar
looks good to me...
Old Aug 25, 2006 | 01:09 PM
  #32
Hopefully it won't be a problem, but I had mine set-up as MM discribed. Under the trany, after the bell housing. At this point you might as well try and see how it works for ya. At least you know you can change it if you have to.
Old Aug 25, 2006 | 01:19 PM
  #33
CrawlinWS6's Avatar
Import Patrol
Looks like a nice set-up
Old Aug 25, 2006 | 01:47 PM
  #34
I think I will try it as I have it. Maybe I will be OK.
My welds look like ****, but I was having some welder problems. As long as they are structurally sound that is all I care about.
Old Aug 25, 2006 | 02:29 PM
  #35
thats my car in the pic you posted, i honestly thought it was run behind the pan, but anyways you ahve the larger OD flex pipe in there.. good luck
Old Aug 25, 2006 | 02:56 PM
  #36
Ryan K's Avatar
Pathological Modifier
The Cruise control is on the drivers side, right where the TTi instructions say it is...
Old Aug 25, 2006 | 10:08 PM
  #37
Default more progress
OK, asked TTi about the mailbox thing. They said just to relocate it with some zip ties, so I did. Still dont know what it is, but I suppose I dont care.
Here are a couple more pics of the crossover clearance to the oil pan. Look OK?
Here is the relocated cruise control, the TTi pic is not too good.
Some pics of turbo and lines around it:
Here are my reworked i/c pipes. Did not turn out too bad I think. I moved the BOV location and added a port for the BOV boost reference.
Old Aug 26, 2006 | 08:12 AM
  #38
Country Boy's Avatar
Senior Member
Looks good. I would wrap the crossover with some heat wrap. Its probably going to heat up the oil being that close to the pan.
Old Aug 27, 2006 | 10:18 AM
  #39
Yep, planned to do that. I am leaving it unwrapped for the intial startup to check for any leaks. Then it will get some header wrap.
Old Aug 27, 2006 | 10:22 AM
  #40
Default Getting close
Getting close to startup. Got the cold side piping hooked up, everything fits OK . My factory radiator hold down touches the cold side piping, but I dont think it will hurt anything. Got the hot side parts mounted up, and hooked up my PCV setup.
In case any were curious, my crossover diameter is 2.25". I saw not much reason for a 2.5" diameter crossover when the log opening and manifold opening are 2.25".
Basically have to finish running some vac lines, bolt up sway bar, and fill it up with oil and coolant, and load a stock tune.
For those following this that want, I have more pics that can be posted. Just ask.
