GT47-88 Build pictures (1998 Formula) ---->
#62
Originally Posted by danimal95
who said i was joking??and it necks down down at the intercooler to 3.5"and then back up with a ventury reducer at the t.b.,there was no way a 4"induction out of the intercooler would have fit through the existing hole with enough clearance to prevent rattles,performance will not be affected by this reduction
John what kmember did you end up using and what type of motormounts?
how big is that downpipe?
#66
PA K-Member from years ago
Poly motor mounts that I had from before. I forget the brand.
there was stock motor mount's in the car,the drivers side is still stock,the pass side required a custom made mount,that was constructed with the end of a bmr control arm and some 3\8 steel plate
#69
LS1Tech Co-Founder
Some pics of the car, turbo parts are removed and are at the coaters. Thanks for the pics Jon:
http://psj.ls1tech.com/gallery/main....avId=x3f0a4fe4
#73
Soon my precious.
What the heck is a ERTL Performance Superdawg 1? Special one-off block?
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#74
Originally Posted by ABeasst
its a setup that for lack of a better way to explain it adds a spacer to the top of the block so a longer stroke can be used. I wanna say you can go to like 500ci
#76
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by TwnTrboCE
No. that is there LS2 Superdeck 2 System. This is just a re-sleaved LS1 block. Well not just... ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#77
How are those 160's doing on the street?
my bad that was the only setup by them I'd heard of.
#79
6 Second Club Moderator
yeah,but not enough to run it throught a car was before dropping it off,then again what fun would it be to work on a car without getting completly covered in grease and oil ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#80
All I want to know is when were going to line them up?
You should at least run a 9.39![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Looks good. About damn time.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
You can take him out after me! He wants a piece of me first.
