what pistons is everyone using
Old Aug 30, 2006 | 01:54 PM
84camaroturbo's Avatar
Default what pistons is everyone using
I have wisco in mine right now but looking at going with a custom built set from ross. with the ofset pins and the special coating at about 7.5 to 1. just curios what people run or if anyone has a set of ross with the coating.
Old Aug 30, 2006 | 04:04 PM
SINISTER's Avatar
i have wisco had no problems with dem
allways herd good about ross
Old Aug 30, 2006 | 04:10 PM
JMBLOWNWS6's Avatar
Ross here
Old Aug 30, 2006 | 05:03 PM
Tiger2o69's Avatar
just bought mahle..
Old Aug 30, 2006 | 05:08 PM
SuperZ's Avatar
mahle -16 cc
Old Aug 30, 2006 | 05:20 PM
Tiger2o69's Avatar
Originally Posted by SuperZ
mahle -16 cc
Is your compression 8.7? How do you like those pistons?
Old Aug 30, 2006 | 05:22 PM
longrange4u's Avatar
Wiesco -32cc Dish turbo pistons
Old Aug 30, 2006 | 05:33 PM
bboyferal's Avatar
Mahle -15cc dished
Old Aug 30, 2006 | 05:34 PM
67Firebird455's Avatar
Diamond -8.7cc dished
Old Aug 30, 2006 | 05:58 PM
chriswtx's Avatar
Diamond -8.7cc dished here as well
Old Aug 30, 2006 | 06:02 PM
Country Boy's Avatar
Senior Member
Diamond flat tops...
Old Aug 30, 2006 | 06:30 PM
NA$TY-TA's Avatar
-15cc Diamond here...... why so low on the compression??? The most many will go is a straight up 8:1
Kyle
Old Aug 30, 2006 | 06:52 PM
Kyle
I agree, you'd think he was planning on pumping 30psi into it with that low of compression.
Old Aug 30, 2006 | 07:37 PM
i have the wisco -22cc dish it figures out to be 8.2 to 1 i am only running 15psi. i was just always told that i will make more power with lower compression.
Old Aug 31, 2006 | 01:43 PM
That is true, only because you can run more boost and advance without detonation. If I were to want only 8psi and still run a good curve, I would run about 9.75:1, 10# would be about 9.25:1.
Old Aug 31, 2006 | 02:34 PM
Boostaholic's Avatar
Diamond -35cc 4.030
Old Aug 31, 2006 | 03:26 PM
stang90gt50's Avatar
Originally Posted by Boostaholic
Diamond -35cc 4.030
What compression does that calc out to?
Old Aug 31, 2006 | 05:10 PM
Blownramair's Avatar
JE pistons
Old Aug 31, 2006 | 05:36 PM
stevieturbo's Avatar
I was using Mahle -16cc in my old 346, now using a custom set made by Ross -25cc
The Ross ones looked so much nicer
Old Aug 31, 2006 | 08:15 PM
kingpin's Avatar
Je Fsr
