Oil line restrictor poll - guys chime in
Originally Posted by Blown SS
On my 6.0 DIY kit, I had to use a .84 N2O jet. I had a good drain too, but without the restrictor, it would always smoke on decel
cool im gonna sang up one of these function7 pieces
and give that a try
any sponosrs sell these i cant get on ebay at work!!!
Update for myself. I got the function7 piece, drilled it out to a .083" to start with and it eliminated the smoking. I then bumped it up to a .096" and it is still good. It gives a very slight puff after a WOT run to redline, but that is fine with me.
cool
1 what is the function7 restriction piece start at??
2 are you useing a -4 line
3 how or you measureing .083 -.096 are you micing it or what??
Originally Posted by SINISTER
cool
I bought the piece for 15$ on the auction site.
I am using a -4 AN feed line
I just used a drill bit to get the diameter hole right, a 3/32" bit will get you about a .094" hole plus a little bit for human error. That is where I got the .096"
yeah i just ordered the piece...will be here on thursday
what im asking is should i slap it on as is or drill out some first??
what does is start out at like .065??
how do i know i need to drill it out more..im useing a turbo off my tti t76 kit so i admigin we are useing the same turbo?
Do you know if you have a smoking problem right now with no restrictor? If you do have a smoking problem, I would probably start out small and work your way up. I started with a 5/64" hole and it totally eliminated the smoking, then moved up to a 3/32" to make sure I did not burn the turbo up.
smokinhawk used a .060" restrictor on his and he ended up frying the turbo bearings, so I would not go any smaller than .075" myself
Originally Posted by Country Boy
Yes. I have one and thats what I was told to start at. If it burns up, then good thing for T-netics killer 1 year warrenty
Lucky dog, I have no warranty
#32
awsome guys
well now how am i going tell if i should drill it out
#33
I would start with a .070"-.080" size hole and work your way up. You want the largest diameter hole that will not cause smoking. If you drill it out too big and the smoking returns then you can either live with it or get a new restrictor.
hum .070 .080 how would i guage that???what size drill bit we talking do i mic the hole???
#34
Math must not be your strong suit?
English drill bits are commonly availabe in 1/64 inch sizes. I suggested starting with a 5/64" drill bit. Take 5 divided by 64 and you get .078". You shuold be able to buy these drill bits a local hardware store.
#35
hahah smack just punched self in *****!! haha
no math and spelling i am the suck
cool thanks
#37
not sure if this was discussed earlier or not but where does the feed line check valve come into this? Are restrictors allowing you guys to eliminate them? Any changes needed to be done with the addition of the restrictor
#38
1) what turbo do you have (brand, model) GT42 102
2) are you using a restrictor in the oil feed line? Yes
3) what size restrictor? 0.060
4) what oil pressure does your engine see near redline? Stock???
5) has the restrictor cured your smoking issues? Yes, with scavenger pump
6) lastly, if you have used a restrictor in the past and it cause problems please post up some details NO
7) what size oil feed line do you use? -5
#40
