Oil line restrictor poll - guys chime in
#43
) what turbo do you have (brand, model)------GT40 88's
2) are you using a restrictor in the oil feed line? yes
3) what size restrictor? .070
4) what oil pressure does your engine see near redline? 70
5) has the restrictor cured your smoking issues? yes
6) lastly, if you have used a restrictor in the past and it cause problems please post up some details
7) what size oil feed line do you use? -4
After 1000mi of not using any restrictor, car began to smoke. Pulled the feed line off today and set it in a 2l bottle. Fired up the car for a sec and it filled the bottom completely.
Then put in 2 n20 jets drilled to .070, no more smoking.
#45
What do you mean feed line check valve? I am not aware I have one, don't know why you would need one.
#48
well drilled her out no more smoke at all !!
good call and just for giggle i removed the fucntion 7 piece and had a bunch of nitros pills laying around so i am going to experment with the pills till i get the exact size figured out..
right now i have a .083 installed no smoke what so ever not even on decell..
ill try and bump it up to like a .096 and see if its all gravy but for right now..car seems to be running strong...sounds so nice
but it seems to be ready for my wedding on saturday!!
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#49
[/QUOTE]
Hey, you and I are in the same boat
. I have been scrambling to get my car ready for my wedding too. Mine is 1 week after yours on october 6. I think at this point mine is ready too
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#50
sweet insert pic of bride to be
clothing optional haha
yeah i got a pretty good base tune in it now!! only drove it about 4 miles so far ha!
#52
Senior Member
Originally Posted by Quick1998Z28
probably a dumb question, but what is the cause of the smoking in the first place? Does oil seep past the bearings and burn out the turbine?
Too much pressure/ volume pushes oil past the seal.
My .060 with my T76 T-netics works fine. No smoking at all.
#53
#56
hey guys... has anyone with a NEWER T-series netics unit used a restrictor as discussed above? I've got a netics T-66 very high mount with a great gravity drain, and the turbo has a built-in oil filter at the inlet which must stay there according to tech support at turbonetics. They say a reducer shouldn't be necessary, but a couple times at startup I'll get a good blue smoke show as if oil got past the rings. I just want to make sure that it's ok to combine this oil filter and a restrictor as well... so that I know I'm not starving the turbo.
TIA,
Kevin
TIA,
Kevin
#57
Originally Posted by MiaSSmaro98
is 0.060 fine for a master power t-70
#59
1) what turbo do you have (brand, model)
1. MasterPower T70 (.50 comp .96 turbine)
2. no
3. n/a
4. 60psi
5. no smoke without restrictor
7. -4 to a T, -4 from the T to each turbo, -10 gravity drain to the pan
2. no
3. n/a
4. 60psi
