Procharger question
Old Sep 7, 2006 | 10:03 AM
Lowery170's Avatar
Default Procharger question
Do any of you Procharger guys experiance a crap load of belt slip after 5200?
Old Sep 7, 2006 | 10:32 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Go SDCE. Go SDCE. Go SDCE!
Old Sep 7, 2006 | 10:35 AM
Lowery170's Avatar
Do they really make that big of a differance?
Old Sep 7, 2006 | 10:39 AM
Read below:
https://ls1tech.com/forums/showthrea...+final+results
Old Sep 7, 2006 | 10:42 AM
Lowery170's Avatar
Thanks, I'll give it a try then.
Old Sep 7, 2006 | 12:27 PM
DJ's Z's Avatar
X2...
Old Sep 7, 2006 | 03:27 PM
Originally Posted by DJ's99SS
X2...
How is your car running?
Old Sep 7, 2006 | 06:26 PM
EPP's Avatar
EPP
Question
You shouldn't have any problems with the eight rib belt at boost levels less than 12 psi. The belt needs to be kept tight, a new belt will stretch after approx 1/2 hr of use, and will need retightened. I tell people to keep the belt about as tight as you would, if you were going to strum it like a guitar. I have seen no ill effects from doing this over the years. Bob
Old Sep 7, 2006 | 06:42 PM
ZexZo6's Avatar
no, but I do get a little bit of wheel or traction slippage at about that RPM
Old Sep 7, 2006 | 06:48 PM
Slowhawk's Avatar
LS1Tech Sponsor
No,we always use 8 rib setups though. Never touched the SDCE,never had a need for it
Old Sep 7, 2006 | 11:05 PM
SR-71 SS's Avatar
Even with the 8 rib kit i was dropping 5 pounds of boost at 4500 rpm, what i found was the tensioner pulley was rubbing against the bracket i drilled out a washer to fit on the bracket side of the pulley and ground it down so that the belt didn't rub against the edge of the tensioner pulley, I also got a blower pulley from Reichard Racing, between the two i am seeing zero belt slip.
Old Sep 8, 2006 | 12:44 PM
Lowery170's Avatar
Thanks a lot for all the info.
