ATI inlet hat on and off track results
Weird, we picked up two pounds of boost swapping out the inlet hat and air filter for a larger one while on my Mustang Chassis Dyno. http://www.exoticperformanceplus.com...Car.php?car=27
Maybe it was all in the filter being the major restriction point. Bob
Believe me if I could pick up 2psi by just taking off the filter and hat I would be the happiest person on earth right now - unfortunately its going to take a bigger blower
Strange....We picked up 2psi too by taking the hat off (stock filter) and saw 76rwhp 103rwtq gain on a mustang dyno. Maybe its the filter then. Where can I get the same filter?
The dip in the no filter dyno is due to belt slippage and we had to shut down at 6K or so because of fuel.
Simple test would be to take off just the filter on the dyno and see I guess, I dont really dyno mine ever..
The filter is from S&B, its just a big 4.5 inlet by 12" long. Plus I have a filter on the hole on the bottom where the bypass hose used to go.
Originally Posted by sscam68
So what's next? Turbo
You going to wait for cooler weather? Or start a new setup?
Originally Posted by kp
I'm just going to leave it, I just pulled the heads for some new gaskets and since I have some room I'll probably go ahead and install the BS3 I have laying here. Just trying to decide if I should get rid of all the stock wiring and do the 'real' race car thing or piggyback it.. I havent driven the car all year on the street really so I may just go ahead try to get some weight off it, its getting a little heavy @ 3470lbs right now
For the sake of mankind, you have to leave the ATI ProCharger D-1SC on there, and continue your assault on the 1/4 mile. Bob
I think thats about all it will do Bob, maybe the new head gaskets will help a little and I can get a little more accurate fueling with the BS3 and pick up a little. I would say high 9.20s to mid 9.30s in real good air will be about it at the present weight..
Bob
I've gotten my car to about 3000 with another 55lb coming off in a week or two and maybe another 20 from going with the dynabatt. I dumped the battery relocation and put it up front. That alone shaved another 26lbs from cable and box. I made a stainless one, weighed 14lbs . Hey it was free! I'll be sitting at ~2925 with the K-member, lower A-arms and drag brakes next. I think that should be good for another 80-100lbs. So I should be at a sub 2900 weight, that's without me in it of course At this point I haven't done subframes or a cage. I'm not even going to bother with the 6 point, I know I'm going to be needing a 10. I haven't swiss cheesed the car (or cut anything for that matter) or gutted the wiring, nor do I plan too. I don't feel it's going to be necessary.
I'm just curious how you got to that weight, especially with all the lightweight stuff.
Time to dry sump it! lol
Bob
Bob
#32
Is that with you in it? And what do you have left to pull?
I still have most of the front bumper support, rear bumper support, steel ATI bracket, I have to run at least 8 gallons of fuel in this tank, big pump, steel braided lines, I run tubes in the slicks, upper PHB is still there etc etc. Its no super lightweight although its lighter then most FI cars. I leave the bumper supports, stock control arms and stuff on the car since I still drive it around a little here and there, plus its just a little safer with that stuff in there IMO.
#37
Originally Posted by FastKat
I wonder if you swapped less back pressure (gain) for hotter intake air (loss) and the effect of each canceled out?
#38
heh, if I sprayed this thing and it stayed together it would be well in the 8s Dont think a 150 shot on a direct port hasnt crossed my mind..
#39
Yeah Frank(sscam68) doesn't realize that when you start upgrading suspension components, adding subframe connectors, adding a roll cage(10pt) a supercharger kit ~80-100lbs, and your weight that it does add up.
Right now his car is a stripped stocker with no added safety equipment. Stock suspended, stock 5lb torque arm, no a/c, no heat, no seats, gutted interior, and without his heavy *** in the car My car goes like 2 seconds slower with him riding shotgun...he's that heavy Just ribbing you frank...why doubt on Kev? Man first the guys in the PCM section and now here
J
J
#40
J
J
