Installed Ling. MAF and 60lb injectors
Old Sep 12, 2006 | 11:52 AM
BLWNZ's Avatar
Default Installed Ling. MAF and 60lb injectors
Put the new Ling. 100mm MAF and motron 60lb injectors. Car made 612whp and I think 592wtq @ 9.5-10lbs. That is with 20 degrees of timing from 5500-6200. My only problem is this MAF is also pegged now. One the phone with Ling they told me they had a car in there shop right then that was making 650whp no problem with this MAF. I figured I would be able to make at least 650whp before it was even close to pegging. Thanks again to Eric and Brian at Dyno Tune Motorsports. Eric played a little with the timing curve from last time and the car drives amazing makes boost faster and pulls really smooth.Highly recommend them to anyone in Ohio.
Old Sep 12, 2006 | 12:31 PM
TransAm6383's Avatar
so the MAF is a waste of money?
Old Sep 12, 2006 | 01:10 PM
BLWNZ's Avatar
besides the fact that it is less restrictive than the stock one I think it is at this point. Anyone heard of scaling engine displacement down and injector tables as well. A tuner I know uses SCT on mustangs does this to get more out of the meter?
Old Sep 12, 2006 | 01:15 PM
MIGHTYMOUSE's Avatar
anyone that thought a 'special maf' would allow an otherwise stock configured computer to make more horsepower.. was wrong.
the computer is the limiting factor, stops allowing larger maf input freq at 12khz.. that is it.
you will have to tune for yourself after that or like you are thinking above, reconfigure the computer to get the airflow into a lower range.. cheat the system.. something i never did. i bailed out and went aftermarket.
there are a lot of things that lingenfelter sales doesn't know, and or won't tell.
Old Sep 12, 2006 | 02:47 PM
smokinHawk's Avatar
yes you wasted money on the maf, should have just gotton a 3bar setup
Old Sep 12, 2006 | 04:22 PM
slow's Avatar
Yes, this can work on a LSx pcm, however it is not as easy as on a GM, since everythign is based on grams/second, not load. So when you do this, you need to remap the spark table as well.
To do it on a ford car, you simiply multiply the injector slopes, engine displacement, and maf transfer functon by X percentage. (and a couple of other parameters)
Are you maxing the maf by frequency or the 512 g/second limitation?
Ryan
Old Sep 12, 2006 | 04:43 PM
frcefed98's Avatar
Like I said in the post about that "magic maf"
Isn't the PCM the limitation??? And I finished up with no thanks, i'll stick to my freebie SD set up.
J
Old Sep 13, 2006 | 09:34 AM
BLWNZ's Avatar
you guys are pretty funny with this magic maf ****. I wasnt thinking it was a solve all deal. I was just looking for a little more room. As for the 3 bar setup I think that is not the solution. I think with weather changes the car would need tuned a lot. And that is not what I want. Also it wasnt a waste of money as I stated before but keep hating its cool.also yeah I am maxing out the 512 g/ps
Old Sep 13, 2006 | 09:36 AM
BLWNZ's Avatar
Wrong.... I was able to get 40 more rwhp with this maf minus the restriction.
Old Sep 13, 2006 | 09:54 AM
Billiumss's Avatar
Sorry to here it didn't work out for ya. Did you guys retune the whole VE table before you tuned the WOT? What were your Ltrims during your cruising cells and at WOT?
Like I told Brian when he called me about your car the other day, do a 2bar OS and call it a day, sure weather will affect it some, but just tune it conservitive and you'll be fine.
Old Sep 13, 2006 | 10:13 AM
BLWNZ's Avatar
I will stick to with the maf for now and the tune is perfect and car drives amazing, Eric knows what he is doing.
Old Sep 13, 2006 | 05:23 PM
eb02z06's Avatar
When you installed the MAF-did you scale the MAF table or leave it stock?
Old Sep 13, 2006 | 07:21 PM
Louis's Avatar
you must re-scale the MAF table or it will virtually not run.
Old Sep 13, 2006 | 07:54 PM
RedHardSupra's Avatar
Louis, what's the magic part? are you scaling frequency or is it just a bigger housing and hope people dont understand that the limit is not in the MAF but in the PCM itself?
Old Sep 13, 2006 | 09:23 PM
BLWNZ's Avatar
we used the table the maf came with but it was off a lot.
Old Sep 13, 2006 | 09:37 PM
tt427ls1's Avatar
LS1TECH Sponsor
What RPM does the MAF fail at...4300? When the maf fails did you try and tune it with the VE tables?
Old Sep 13, 2006 | 10:44 PM
onfire's Avatar
Coal Mining Director
My maf maxes (or fails) at 3500rpm.....then it's rpm vs PE for the tune.
Old Sep 14, 2006 | 07:47 AM
WAHUSKER's Avatar
This is the part that confuses me. Does not HP Tuner say the VE table is for when there is a MAF failure. Meaning when you max the MAF out, or it fails, the PCM uses that table to scale the a/f? And then it uses PE as a multiplier when you go WOT?
When you SD tune, by disconnecting the MAF aren't you running solely on the VE table? Which still leaves you with the '100' VE table limitations.....at least I don't see any changes at any number over 100. So you can't fine tune at hi flow. All you have is the PE multiplier?
And then after you plug the MAF back in you run into the 512g MAF limit. Mine maxes out around 5k.
Old Sep 14, 2006 | 07:57 AM
Louis's Avatar
There is more to it than that. I spent 3 days strait, almost 40 hours on the dyno with it. It makes the same power as a NA SD tune with out the driveability issues related to a MAF.
Yes the PCM is limited, but its 4" in Diameter. The Measured Hz went down by a significant amount, thus raising the roof, however not totally removing the handicap of the MAF.
Old Sep 14, 2006 | 08:22 AM
onfire's Avatar
Failure is a word that should not be used for a maximum limit. I'm not going to use it anymore as it's confusing. 512g/s is the max any maf can read since it is a hard code in the ecm. After you flow that much mass air, the only way a maf tuned ecm can adjust the fuel ratio is through RPM vs PE.
The Stalk Insert Element in the LPE maf can be scaled to report the 512g/s at a different point on the hertz scale.
If a maf truly "fails" (burns out,etc) the VE tables will be used in the lower rpm areas,etc.
There is no fine tuning above 512g/s....just RPM vs PE....and it better be conservative or pop goes the weasel.
