Custom Turbo's keeping AC???
Old Sep 16, 2006 | 05:29 PM
MachoCamacho's Avatar
Default Custom Turbo's keeping AC???
I know the truck manifold one cannot, anybody running a custom setup that they did keep the AC? where'd ya moutn the turbo(s)? single or twin? intercooled? info needed for placement(i know basically all i need to about turbos plus i have friends with custom turbo'd cars, just need placement ideas).
Old Sep 16, 2006 | 05:45 PM
ls1king000's Avatar
I was planning on this https://ls1tech.com/forums/forced-induction/547974-truck-manifolds-ac-take-look-please.html
but it was already overpriced and they just raised the price again recently. MIGHT clear truck manis
Old Sep 16, 2006 | 05:52 PM
TchargedLS1TA's Avatar
If you want to keep your A/C, I think the Turbo Tech street kit is the only one that does. Even with it, you are only limited to maybe 600 hp on a built motor. If you want big numbers, the A/C will have to be sacrificed for some headers.. Log style systems suck, but are your only option
Old Sep 16, 2006 | 05:58 PM
Originally Posted by ls1king000
I was planning on this https://ls1tech.com/forums/showthread.php?t=547974
if that was only a AC pulley setup i'd go for it....
Old Sep 16, 2006 | 06:21 PM
engineermike's Avatar
Logs aren't so bad. I've run 143 mph at full weight with a log header and T76GTS on my old LT1 with a blower cam. There's more to come also, as the run was made with 17's up front in 90+ deg heat and there's more left in the turbo!
Mike
Old Sep 16, 2006 | 07:43 PM
Dragframe's Avatar
i wouldn't dog log systems so much...
Old Sep 16, 2006 | 09:27 PM
longrange4u's Avatar
Welllllll you could always go with a rearmount setup! Right Steve?
Old Sep 16, 2006 | 09:28 PM
StoleIt's Avatar
NKAWTG...N
Well...if its custom...then it is up to the person who builds it. Now if you want a production turbo kit from a sponser or company...then I think all you have is the TTi Street Kit and one of TurboZone's kits, or rear mounts.
Old Sep 16, 2006 | 09:38 PM
GotV-8's Avatar
What is TTi website, or a site that you can read up on them?
Old Sep 16, 2006 | 10:01 PM
bboyferal's Avatar
There are others that keep A/C and use tubular headers. I can think of at least one.
Old Sep 16, 2006 | 11:03 PM
MiaSSmaro98's Avatar
my own kit is gonna have ac
Old Sep 17, 2006 | 12:53 AM
Ha ha, but do you dare go there...
Old Sep 17, 2006 | 09:12 AM
bboyferal's Avatar
Nope.
Old Sep 17, 2006 | 08:00 PM
~JOSHUA's Avatar
Find a used Incon kit. Cast manifolds, very durable.
Old Sep 17, 2006 | 08:06 PM
bboyferal's Avatar
I never undetstood why anyone with an Incon would want to sell their Incon.
While I'm pondering life's mysteries, I continue to be perplexed trying to understand how no one has emulated the design, i.e. the low hanging twins, etc. and come out with a "copy."
Old Sep 17, 2006 | 09:33 PM
Slowhawk's Avatar
LS1Tech Sponsor
Incon is the only one I would think about for keeping the AC.All the others require running pipes under the subframe.Would rather loose the AC than have pipes under the frame
Old Sep 17, 2006 | 09:45 PM
#cough# STS has the same prob
THat is why I ditched the STS and am doing a custom rearmount...
