Ohio forced induction inc single turbo numbers GTO/f-body
#41
Well I got the 80mm turbo today. Jose says that its the same as a gt42. The flange is a t6 inlet. I bolt it up to the t4 flange with 2 bolts just to see if it will fit in the same spot. Well guys it fits like a charm. Just need to rework the croosover a little to move the turbo so I can get the 3.5DP in there. Should have some pics by monday on the crossover setup with the turbo on it. Then will have the DP pics later after that.
#42
#44
Originally Posted by bowtieman81
Engine is stock according to his post. I doubt he will be turning it up to 15 psi on stock engine.
Their base kit uses a T67 turbo, but would like to confirm that is what they used.
Very good numbers!
Very good numbers!
#46
Originally Posted by Gold Phoenix
Why not? Rob Raymer did it to a 120K miles '98 Formula with a T74. Now, he have a 50/50 mix of TurboBlue and pump gas with a straight methonol injection and made over 700whp and 840wtq. That was with a stock long block with 918 springs and through a M6. The motor survived many dyno pulls and drag runs. What keeps you from destroying an engine is good, safe tuning.
#48
joel excellent!! I know its been asked but i/we would love to see some cold pipes installed...
question, S88 is a 3.5 DP or a 4" outlet? I think its bigger then that but i could be wrong?
#49
#51
Originally Posted by white2001ta
Let this guy get to work so that he can finish my kit. .Joel so far the kit looks great.
#52
#54
Have not recieved the kit yet, im getting parts coated and polished so it will be a little more time than normal. The turbo I will be getting is actually the S-85 Turbo as the S-88 was on back order and would be 3 months before it would be avaliable, and I figure the S-85 will give me the numbers I want anyway. Looking at putting 900whp with this kit and the engine that I have, which is also getting upgraded.
#56
Originally Posted by DrTurbo
The S85 is an animal as well. The DR cars use to run mid 8's @ 165-169 with them.
#57
Originally Posted by burnham187
That is what I was told, which is why I wasnt too worried about downgrading to a S-85 turbo. Either way the plan is to keep all accessories and A/C in stock position and be able to run 900whp.
