AZPS New part for F/I applications
Originally Posted by Chad@AZPS
Just the 3 ports. We can have some made with more ports for FP regulator, BOV, wastegate, and a boost guage. It is better to have dedicated lines to each accessory than have many lines teed off one.
Chad
Chad
Senior Member
That would be badass if it had at leat 4 ports. I need then for WG, BOV, boost gauge, and a BRFPR. Ill buy one if you can get it soon. I was going to use a bunch of Tees and look ghetto.
What size is the main line and the ports?
Originally Posted by 2002/Black/SS
i asked before but, what is the size of the port on the peice? would i need a npt fitting to screw in and then attach the vacumm ine to it? im not sure what fitting i need to make the hole fit a 1/8 inch vacuum line, i ask because if i buy teh piece with 3 NPT fittings it would cost upwards of 40 bucks....
Thanks,
Chad
Thanks,
Chad
no no no all you guys are wrong its for your piston return springs, but you have to have a left handed screwdriver to install it otherwise if you install it wrong your mufflers bearings might go out.
Thanks guys, ordered one today !
OK, I'll admit it, I've been using one of those icky white plastic universal "T" adaptors from AutoZone with a couple of band clamps around the ends...
Rob (Bad30th)
Rob (Bad30th)
You don't need to use a left handed screwdriver but you do need a metric cresent wrench or you will destroy your muffler bearings like I did.
#36
Originally Posted by White.Lightning
Not a big deal, but why not offer a "kit" with 3- 1/8" fittings and 1- 1/8" plug?
Just a thought to save people a trip to Home Depot
Andy
Andy
#38
Originally Posted by Ponyhntr
It's about $25 with all the fittings you would need. No trips to the parts/hardware store!
AZPS can we order through PM with something like paypal?
#39
Originally Posted by JAvenger007
Is this avail for sale seperate though? And who can we place the order to?
#40
Andy
Andy
Thanks,
Chad
