H2o2 / ASC Methanol / Nitromethane blend - for water/alcohol injection systems
I was looking for places to buy methanol from and came across this and was wondering if anyone has heard of or ever tried it.
http://www.dfwx.com/fuel.html
For water injection systems, this is the most potent mix offered anywhere and will produce significant horsepower increases in engines equiped with water/alcohol injection systems. This unique blend of O'varde Water Injection Blend is 51% water to 42% and 7% Nitromethane. If you have a water/alcohol injection system, you will want to try this for your performance engine.
We tried a little bit of nitro in a diesel before.. We did more like a 60% water, 20% meth and 20% nitro mix though.. We picked up about 30 hp over just a 60/40 mix of water/meth. But damn it ran hot, normal EGTs were about 1450*F, with the nitro, it ran well into the 1600*Fs
Originally Posted by Bill @ Hi-Flo Turbo
h2o2 is hydrogen peroxide, not water
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Wonder if you could buy straight hydrogen peroxide and then ignite it
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Out to make pretty good power
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
