Single Turbo Project!
Old Sep 22, 2006 | 07:07 AM
NVR KNO's Avatar
Default Single Turbo Project!
hey guys. i am thinking of going the forced induction route. i have been looking at quite a few different kits and i think i found one i like. it is from TURBO ZONE. the street-zone kit. i am getting the kit with the tubular headers so i can keep my a/c. here is what i have so far.
turbo kit(t-76/blowoffvalve/wga/intercooler/tubular headers/all piping)
install/tune(jeff creech)
gauges(a-f/boost/fuel pressure)
pod pillar(3 gauges)
42lb injectors
fuel pump
spark plugs
everything comes out to around $9600. does this seem high? or am i missing anything? i dont know a whole lot about turbo kits, but im trying to get more and more information. any insight would help. thanx.
Old Sep 22, 2006 | 08:38 AM
KraZy's Avatar
Seems a bit high, but I built mine myself......finding deals where possible. (I also had to remove my A/C though)
I am tuned by Creech too. Are you in NC? I'm down by the coast.
Old Sep 22, 2006 | 08:49 AM
99SS-T's Avatar
the price seems right since u got install in there. I woudl definatly NOT get 42# injectors. Dont even think about them. Get 60's and be done with it. The 60's wont handle the power u can make with the t76 but atleast they can get u to 750ish with out issue.
Also u need to get atleast 918 springs and hardend pushrods. The springs make sure that teh valves can close with the added pressure and the pushrods are prolly bent if ur still using stockers. They bend over from the smallest mistakes.
U should also get a twin intank setup for fuel. If u jstu put 1 pump in now ull be limited to about 500 rwhp. And if that is all u wanna make then get a smaller turbo so that it will spool faster. But i woudl imagine that u wanna make more then that. U dont have to do the feed lines and rails and FPR atm but it would be a good idea.
Make sure all ur spark plug wires are in great shape if u have aftermarket ones and replace them if they are stock. They need to get a hell of a spark in there so that it dont get blown out by the air movin around.
Ur gonna need a boost controller unless u got a tiny *** spring in there.
I cant think of anythign else atm so GL to ya man
John
Old Sep 22, 2006 | 10:10 AM
NVR KNO's Avatar
thanx man. im not really looking for the most power output right now. im still going to have a stock rear and tranny for now. im not going to race anyone from a dig anyway, i might do an occasional roll race but other than that... its not a track car or a daily driver, just pretty much a cruiser. i only drive it a handful of times a month. i think 500rwhp will be fine for now. i am sorry i made a typo, the turbo is actually a t-67.
Old Sep 22, 2006 | 11:33 AM
67Firebird455's Avatar
Yeah, a 67 trim sounds more reasonable for your build than that 76! I have a 70 and am pretty happy with it. +1 for forget 42lb injectors if you plan on increasing the boost much.
Old Sep 22, 2006 | 11:38 AM
99SS-T's Avatar
Even if u stick with 500 rwhp for ever dont get 42#er's. its only a 100 or 2 more for the 60's and they are much much better. I made 531 rwhp on the 42's and it was the JAGGED edge of usable for the injectors.
U mentioned in ur reply that ur not lookin to make the most power atm. Im assuming u use the words "right now" to say that u plan on doin it in the future. It really is a waste to do things 2 times when u can pay just a little more now. the 255 intank pumps are 120 a piece so thats onle 120 extra to get 2 of them and then teh little y block dont cost much to make them work and then u have enough fuel outta the tank for ALOT more power. Ya dont need to worry bout the lines and rails and FPR atm but atleast dont do **** 2 times that u can do correctly now.
Ur choice but speakin for experience, U will REALLY hate it when u do it oer later and have used parts sittin aroudn that noone wants. Like a inline pump and 42's. GL man
John
Old Sep 22, 2006 | 12:20 PM
NVR KNO's Avatar
oh no, im definetly goin to go with the 60lb injectors now. i do plan on turning up the boost down the road, but not til i forge the internals. and get a rear. i understand where you are coming from with the whole do it right the first time. i was just letting you know that im not looking for a great amount right now, 500-550rwhp will do fine for me now. a big difference from 360-370rwhp now. now, will my tranny be able to handle that kind of power when im banging the gears?
Old Sep 23, 2006 | 01:47 PM
NVR KNO's Avatar
i have a question. if i go ahead and upgrade my springs and pushrods, then what can i up the boost to? will it be able to handle more boost by doing that?
Old Sep 23, 2006 | 02:21 PM
longrange4u's Avatar
You have allot more to worry about then just your springs and pushrods... is your lower forged and built for boost?
Old Sep 23, 2006 | 02:23 PM
NOSjohn's Avatar
Restricted User
The springs and PR's will allow you to run your motor to a little higher RPM. I wouldn't run too much more than 5-6psi on a stock motor without a good tune, gas and possibly some alky.
The 60 lb.hr. injectors are good for 115hp each, so you're safe at 80% duty cycle at about 725-735rwhp.
Old Sep 23, 2006 | 03:00 PM
NVR KNO's Avatar
well thats good to know. my bottom end is stock too. im going to have a good tune and what octane gas would be good?
Old Sep 23, 2006 | 03:19 PM
Got Me SOM's Avatar
man be prepared to have to upgrade everything in the future. i'll tell ya right now you'll need a better clutch.
good luck it will be fun having that new found power.
Old Sep 23, 2006 | 03:46 PM
NVR KNO's Avatar
oh i have a new clutch. a spec c stage 2 plus.
Old Sep 23, 2006 | 05:23 PM
NOSjohn's Avatar
Restricted User
Depending on where you live, try to stick with 91 - 93 octane. If you're going to run even higher, you'll need to adjust a few things. This includes running race gas valves in your waste gates.
Old Sep 23, 2006 | 05:57 PM
Mr. Bungle's Avatar
My spec 3 took a dump on me after 3000 miles of driving at about 500rwph now i am at a stage 5 and love it. Good luck sounds awesome.
Old Sep 25, 2006 | 06:53 AM
NVR KNO's Avatar
i was wondering how much power my clutch would be able to handle. although i wont be running it all the time. its not going to be a track car, just a cruiser when the weather is nice. so hopefully the clutch will hold up a lil longer.
Old Sep 25, 2006 | 11:05 AM
NVR KNO's Avatar
what kind of pushrods and springs should i use for my setup? i heard comp cam or manely, but dont know for sure. thanx.
Old Sep 25, 2006 | 12:18 PM
NOSjohn's Avatar
Restricted User
Comps are good and they have good customer service.
