New best
Old Sep 26, 2006 | 12:46 AM
SSilverSSurfer's Avatar
just hit 7's already and quit teasing
Old Sep 26, 2006 | 05:55 AM
cablebandit's Avatar
Awesome Mike!!!!!!! Can you ramp boost down a tick and then bring it back up? Would moving your instant center forward any help since you have plenty of traction at the hit?
Old Sep 26, 2006 | 07:04 AM
Reckless's Avatar
Super Moderator
I may have the pass on video Mike. I will check when I get home. 8.30's on the 6th?
Old Sep 26, 2006 | 07:34 AM
Navy David SS's Avatar
Originally Posted by TwnTrboCE
Your motor ok? Last I remember reading you lost oil pressure?
I think the limiter will allow you to come out a lot harder. Your is flat *** flying. The BS3 doesn't control your boost?? We will get mine set up through AEM to gradually add boost.
Not sure on the engine yet. Yesterday was the 1st day with no rain in over a week. No big hurry as the local track is closed. We are looking for some place to race once we get the twin-turbo 93 Mustang done. Easier to travel in 2's.
David
Old Sep 26, 2006 | 08:32 AM
TwnTrboCE's Avatar
Sweeeeet. 8.30's or possibly a .20 this Saturday at Trails if not Thursday at Kilkare. If I can stay in it and get it leaned out up top. My BS3 was only scaled to 6500. So I could only adjust to that. It was going 10:1 A/F at 7000+.
I've never needed anything else to help control the boost on the CE. Just set it on kill and adjust the timing as it was ramping to calm it down. We have some other things we have done in the past that work. I was at the track competeing and didn't want to make a bunch of changes and cost myself a win.
Stay tuned. But I will tell you. This one wont go 7's.
Old Sep 26, 2006 | 10:26 AM
onfire's Avatar
Coal Mining Director
How low can you drop timing in the mid range to drop boost?
I'd like to limit the ramp up in the 3200-4500 range. Timing is at 15 there and I've thought of dropping it to 12 or 13.....any thoughts?
Old Sep 26, 2006 | 10:30 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Congrats your car is awesome!!!!
Is this with the 88/98 Mikey?
Old Sep 26, 2006 | 10:40 AM
MIGHTYMOUSE's Avatar
which transmission are you currently using? i'm looking for good people to get a 4l80e from
Old Sep 26, 2006 | 11:03 AM
fash00's Avatar
rossler
Old Sep 26, 2006 | 11:12 AM
98CustomSS's Avatar
Your my hero Mike!!!!
Old Sep 26, 2006 | 11:22 AM
Stay tuned. But I will tell you. This one wont go 7's. :devil:
thats ok if it doesnt, your car still runs lke a raped aped
Old Sep 26, 2006 | 11:23 AM
  #32
TwnTrboCE's Avatar
I know.
PSJ, the turbo is now a true 98 thanks to Jose.
onfire, drop it as much as you need till you get it to do what you want. It won't hurt anything. Mine usually responds well with a 2* change but it wasn't this time. Like I said I was afraid to make too big a change and loose the round.
MM, I'm running the TH210 now. I broke the pump in the 4L80E at the track on Drag Week. I'm sending it back to Rossler soon for some extras to help me race it next season. Your going auto now?
Old Sep 26, 2006 | 12:21 PM
  #33
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
I know.
no prob
Old Sep 26, 2006 | 12:44 PM
  #34
NA$TY-TA's Avatar
I know.
Mike what Rear gears out back??? 3.50's??? Spinning it to 7800 is nuts
I do mis OD with this glide........ Maybe one day a 4L80E or a GV OD Unit.
Kyle
Old Sep 26, 2006 | 01:28 PM
  #35
FormulaFire's Avatar
Whoa.. you going auto MM?
Old Sep 26, 2006 | 03:01 PM
  #36
if i can get hooked up with a good product for a good price
Old Sep 26, 2006 | 03:20 PM
  #37
TwnTrboCE's Avatar
Kyle
Yep still 3.50's. I prefer to call it crazy. The big turbo and the motor seem to work well together at the high rpm. No signs of float and the higher I shift the faster it goes.
Old Sep 26, 2006 | 03:24 PM
  #38
Mike
One more question on your converter. MidWest Converter? Any problems. Seems to be holding your power. What stall?
Thanks
David
Old Sep 26, 2006 | 04:05 PM
  #39
ABeasst's Avatar
whats a 4l80 from rossler with all the goodies to handle 900RWHP with a transbrake cost?? I assume 4-5K?
Old Sep 26, 2006 | 04:32 PM
  #40
y2khawk's Avatar
Mike
If you're gonna rescale your cal, give me a shout. I reworked Tom's a bit before this past weekend to get some resolution in the upper RPM, and swap over to the 4 BAR sensor
I've got some stuff I wrote to rescale the cal map since you can change the load/speed axes but the actual cal doesn't change in any way. You have to rework the numbers by hand. Screw that
If I get motivated, maybe I'll work on the cal compare stuff too. Not being able to look at what changed from *.big to *.big drives me nuts.
