Those interested in Magnuson kits for F-body, step inside
#42
Doesn't lowering the K-member and crossmember affect the whole suspension geometry of the car? It would affect the driveshaft angle along with the whole front-end suspension.
Have you checked into this problem, and could you share the results with us.
A friend of mine does suspension setups for a Nascar team, thats his job, flying around the country to all the races and tweaking the cars suspension. Next time we talk I'll ask him about lowering the K-member, and what affects it has on the suspension.
#43
Good point, I would be interested to hear what your NASCAR buddy thinks, PM me when you talk to him. This setup is not any different than a lift kit on a 4x4 truck, in fact trucks with massive lift kits run the driveshaft at much more extreme angles. The trans crossmember is in the stock location, so I am putting the front u-joint at a different angle than it originally was, but it's not enough to cause any problems with the joint itself. My pinion angle is at -3 degrees, which is right where it should be to have the driveshaft straight under power. I am taking the car for a 4 wheel alignment tomorrow, and I intend to have it aligned to factory specs. I will post the results here.
I have put over 200 miles on my car in the last 2 days, and believe me, they haven't been easy miles! I am beating this car withing an inch of it's life everyday to try and break something so that I can address any issues before production kits are shipped. So far not even a hiccup or drop of leaking oil! this thing is living up to all of my expectations and then some! Stay tuned!
By the way, thanks for the laugh Houdini, I have never actually seen a thermo nuclear credit card
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ed
#47
The tranny crossmember would need to be lowered as well to keep the correct geometry of the motor/tranny. During mockup of my 36 Dodge I was told to keep the motor/tranny line -1* to -3* from level in the chassis?
#48
Congrats on doing something for the F-body that most companies have run away from like the plague ! I definitely think you have something if you can package in a nice easy plug and play kit (sounds like that is what your doing). If you actually made it work with the KB that would icing on the cake. I have a LT1-6spd car, so the question remains will you try to address the 93-97 LT1 F-body crowd ? Good luck in your endeavor
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
#50
thanks for the kind words guys, I've been working on this for a while, so it's good to be close to the point of selling them.
I will definately look at making a kit with the bigger blowers, but right now I need to get this kit fully off the ground, then look at other upgrades.
As for the LT1 question, I'm sure I could do it pretty easily, but my concern would be in the factory LT1 pistons. I would want to see a set of Mahle or equivalent pistons, which would also give the opportunity to lower compression
then I think it would be pretty simple to adapt a SBC blower manifold to the Magnuson or KB or whatever.
Ru2n00n3er- call me at the number in my sig, we'll hook up. I'm an hour away from Muncie
Ed
Ed
#51
Ed - I'm glad I gave you a chuckle, but believe me sir, it's no laughing matter. Klaxons go off when I open up my wallet, I need to wear nomex gloves when I whip that badboy out... you could use the damn thing as a hotplate!
In all seriousness, you should place a call to Sam Strano to find out about the whole suspension geometry thing. The man knows his **** when it comes to F-Body suspensions, he has been the go-to guy for may people on this board regarding suspension related problems. I have spoken with him on a few occasions, he has always been friendly and understanding with all questions I have asked him... even the stupid one's.
Sam Strano-Owner Strano Performance Parts
2 time SCCA Solo2 National Champion
2002 SCCA ProSolo Series National Champion
814-849-3450 tech
800-729-1831 orders
www.stranoparts.com
I will still try to reach my friend this weekend to see what he has to say also, and will respond back to you with a PM.
If you could make the Magnusen mp122, Whipple or Kenne Bell screw chargers work on a LT1/4, I would care less if it poked out of the hood. In all honesty, I would almost prefer it. I think a black powdercoated blower sticking out of the hood of my white Trans Am, would be just about the best looking mod I could ever do to my car. If you think it's at all feasible, I officially offer you the use of my car as a prototype platform... just say the word brother!!
God bless!
814-849-3450 tech
800-729-1831 orders
www.stranoparts.com
God bless!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#53
I have never been able to understand why a company could not make an offset intake/adapter to place the blower a little more forward on the engine to clear the cowl and shorten the blower drive snout to be run off of the serpentine. I would not think this would be that hard to do and once a cast was made it would be easy to sell them and make killing at first in this community. I am really suprised KB or Whipple did not do this for us.
#54
I always thought the very same thing. Have the lower blower manifold angle forward somewhere in the range of 35-45 degrees, geting the blower itself, out from under the cowl.
With the exception of maybe the Magnuson mp112, any other positive displacement blower is going to require cuting of the hood, and the blower unit WILL end up above the hood. So, just accept this fact and push the damn thing through the hood. If you like the look of a pulley and blower above the hood line, then leave it as is, if not, then I'm sure someone will see some money in a new hood design made to clear positive displacement blower units.
I for one, want the ungodly amounts of torque off of idle that only a screwcharger can provide... smash that **** through the hood and be done with it!!
Done right...
MP112 = 500-550rwhp
MP122 = 525-600rwhp
Kenne Bell 2.6 = 600+
Kenne Bell 2.8 = http://forums.corvetteforum.com/show....php?t=1468770
Whipple 3.3L =
![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
#57
I modeled the F-body suspension set up last year for a Vehicle Dynamics report. All you would need to tell me is how far the K-member is lowered, and I can edit the files, and tell you the new Roll Center location, camber gain, etc. I am very pleased that you went on a limb and did this, without cutting the cowl. Shoot me a PM and we can get some info going.
#59
Hi Warren,
If the cradle wasn't lowered, I would have to do a lot of cutting, and probably run into the same issues others have seen with re-locating the wiper pivot. The spacing of the K member is no big deal at all, but if a customer doesn't want to lower the K member, and would rather do more cutting , I am willing to work with them on a one on one basis. Same thing with the 90 MM snout. The only way to keep the price of this kit in line with the Corvette kit is to keep it as simple as possible. My shop will be open on Halloween , once that happens, I am willing to do whatever custom work people want.
More detail pics and dyno graph coming todaay.
Thanks,
Ed
Thanks,
Ed
