8:1 or 9:1 comp
Old Oct 1, 2006 | 09:19 PM
clebmotors's Avatar
Default 8:1 or 9:1 comp
F'd up a piston and a sping in the heaad.Right now I have 8:1 compression with d1 procharger 15 lbs of boost and 75 shot nitrous, gettin higher flowing heads and the same piston,? or should I go 9:1 compression with stronger heads (internals)?
Old Oct 1, 2006 | 09:57 PM
ty_ty13's Avatar
7 Second Club
id say stick with 8:1.... you can always put more spray to it or get an F1c later.
Old Oct 1, 2006 | 10:19 PM
onefastss223's Avatar
I would say 9.0:1 if not a little bit higher for a blower car. Just beef up the internals and you should be good to go. On 8.0:1 you'd have to run alot more boost to make the power you could on a 9.0:1 CR engine. Just my thoughts though.
Old Oct 1, 2006 | 10:28 PM
TrakDay's Avatar
Honestly on a blower setup I like 9:1 compression. Little more low end.
I originally had a 408 built for my F1C Procharger at 9:1 compression and will probably go with a TT setup on 9:1.
Old Oct 1, 2006 | 10:29 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
One extra lb of boost will more than make up the 1 point cr difference. Plus the 8/1 lets you run a lot more than 1 extra lb at the same timing as 9/1. Only reason to bump the compression up is fuel economy or off boost throttle response. CR usually amounts to about 3-4% per point power difference. Boost is 7% minus whatever it takes to drive the blower, so at lest 5-6% per lb. Obviously these are general guidelines that can vary considerably.
Old Oct 2, 2006 | 07:22 AM
ty_ty13's Avatar
7 Second Club
the only reason to run 9:1 is if you know you wont ever have a bigger blower than a D1sc.... i plan on running a larger one down the road so i went with 8:1
i should have some track times this weekend...
Old Oct 2, 2006 | 12:26 PM
NoGo's Avatar
I vote 8:1.
I run 8:1 @ 17lbs on the street on pump gas. I have done this for quite a while and it is very reliable. The nice part is that I can turn it up further (ie bigger blower) if I ever chose to and not have a problem.
I originally ran 8.75:1 (something like that) when I was ironing out the setup. I changed heads and went to 8:1 compression. There was no difference in SOTP low end. FWIW
Old Oct 2, 2006 | 01:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Keep what you have unless you are wealthy. Blower + nitrous = an aggressive combo.
Old Oct 2, 2006 | 04:49 PM
clebmotors's Avatar
I just want the best setup that wont blow up on me, I think 8.1 sounds like a winner though so Ill probaly stay at that, Thanks guys
Old Oct 3, 2006 | 08:31 AM
EPP's Avatar
EPP
Smile
We build our ATI ProCharger street/strip engines for 9.0/1 to 9.5/1, and run them at 14 to 16 psi on 93 octane without any problems. The higher compression ratio will give you good fuel economy if you are still on the streets with your car. The 700+ rwhp D-1SC equipped Corvette we recently finished still gets 28 mpg, and this customer recently drove this car from Chicago to Virginia on a vacation with his daughter. Bob
Old Oct 3, 2006 | 03:59 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
8.5:1 Would be a nice compromise. Best of both worlds.
Old Oct 5, 2006 | 03:56 PM
Silverback's Avatar
It’s not really that simple… like with an NA combination you want to make sure that your setup is well matched. Just like NA you’d probably want to run a more mild cam with less compression and what will ultimately end up “right” will depend on your intended powerband, how the car will be used, fuel octane, the rest of the engine parts that you’re matching to… It is possible to end up with a combination at 9:1, with a lower DCR than at 8:1 and have the 9:1 combination be less detonation sensitive then the lower compression setup.
