Questions for the turbo dudes!
Is it normal for the car to sound like its running on 7 cylinders? Its got that funny blub exhaust.
How much of a difference is 6 PSI from n/a? I have a 9 psi spring, but I figure due to the FMIC and 3" piping, thats why Im seeing 6 at the intake. I feel it pull, but not like I though it would. I plan to run 10 psi. I am on a very rough tune. Base changes to the VE (2 bar SD system) and a borrowed timing table
Will a dialed in tunes make that much of a difference?Bucking... I have 60#ers and I have bucking while crusing.. Is it a bad IFR table (I used the spreadsheet for 60s, but I have a BRFPR and I only see ~48 PSI while crsuing) or too much timing? My WB shows ~14.8-15.0 while crusing.
Any special tuning need done to the IFR table or anything for a BRFPR?
Im sure Ill have more Qs.
The exhaust note is different; mine sounds a little strange when decelerating. It sometimes backfires too (still tuning).
You should feel noticeable difference at 6 psi with a good timing table. Mine was a dog at 5 psi until I upped the timing a bit. Then it would spin in 2nd just pushing the pedal down. I will let you know if a dialed in tune makes a difference when I get my new WG. What compression ratio are you at?
Your car should not buck, I have 42 lbers and the car does not buck at all.
I have forged flat tops with 2cc reliefs, stock 6.0 heads and 02 MLS gaskets. I figure its around 9-9.2:1. At WOT, Im seeing 11:1 also.
I keep this updated tomorrow as its too late to troubleshoot now since I live in an apt.
This is going to bug me all night now.
I share most of these problems with you. No power from 0-5psi and then it really doesn't haul after that...just "goes" Boost builds real fast too up until 9psi, so I'm lost. Tune looks great, got great timing, excellent A/F and no KR.
I'm going to pressure test my IC tubing from the outlet of turbo to right before the TB. If no leaks pop up there, the intake manifold will be coming off for O ring replacements and all vacuum lines post TB will be checked and replaced.
I'll also be taking my WG apart to see if the internals are jacked up.
Best way to describe this situation, my car is rejecting the turbo implant
and go with something else. This wouldn't be your first time.
J/K and I hope you get it figured out. I can only imagine trying to upgrade to something better and and having it not work as good as before. 1 step forward and 2 steps back.
Couldnt be a lean buck if the WB AFR is 14.7-14.9 at cruise, I dont think. The WB shows all is good. Im thinking the bucking could be from a dead cylinder lighting off...
I had a fouled plug that was giving me trouble, maybe start there.
I did find something interesting... Im blowing holes in my TB.. lol ported and epoxied TBs arent good for FI
Boils down to time, i'm trying to keep it on the road since its my DD for about one more week...that takes away wrenching time to figure stuff like this out. Tune is there though. Wish I had a stenod I could drop my car off at and pick it up making 1 billion hpIm about this . close to selling it all LOL.
Keep chippling away at it carl you'll get it.
Cruise afr is 14.6, which is what the computer will command. You can change that if you want, but I don't see why.
I would recommend changing your PE versus TPS engagement if you have not done so.
