Is anybody running the intercooler spray bar?
http://www.holley.com/16034NOS.asp
I am still on a stock bottom end. Therefore straight up NOZZZZ into the engine is out of the question (at least unitl I get back from Iraq for the second time).
We have seen air inlet temperatures plummet down to 39 degrees with our EPP350Z Deepfreeze, allowing the engine horsepower and torque to dramically climb! Bob
when you run the spray bar use a toggle switch to activate it and right after you do your burn out turn that **** on let it ice up the IC and leave it on the whole run.... you will see a difference.....
its a cheap option that doesnt take any tunnning... it just pulls the IAT's down... i'll try it if my combo doesnt yield the wanted results..
im good friends with the holley truck driver and he likes them.... and he isnt a biased person... he always tells me the truth.
The owner of that 350 could go completely rice and illuminate it with a couple of blue LED's... or has he already?
as for cooling the core, well they do for a few seconds. once underway how long does the intercooler stay under ambient temps?? not forgetting that the ambient air that normalyy cools the intercooler is now working against you in the fact its pulling the IC temps back uptoi ambient!!!!
a much better and much more proven way is to spray into the intake! you tipicaly see about twice the power gain to the size of the shot. so a 25shot will give you between 40 and 50 bhp. this is cos you are DIRECTLY cooling the inlet air, not the intercooler.
also how much N2O would you use??? looks like you would need a fair bit to have any great effect on IAT! why not just use meht?? proven to work VERY weel, is proberally cheaper and much easier to install (no presureised tanks!!!!!).
ps. not having a go at the system, just dont feel they have much use.
thanks Chris.
BOSS APPROVED!
