Nothing too exciting to talk about yet had some problems...
Old Nov 9, 2006 | 01:52 PM
  #81
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
867rwhp at 25psi, 787rwhp at 21psi.
Old Nov 9, 2006 | 02:20 PM
  #82
SSilverSSurfer's Avatar
when you heading to the track for that 8sec timeslip?
Old Nov 9, 2006 | 03:13 PM
  #83
KHShapiro's Avatar
so what ended up being the real problem incase i missed it in one of the posts? Did you also pull the heads , if you did how was the mls?
Old Nov 9, 2006 | 03:55 PM
  #84
LS1Tech Co-Founder
KH, changed:
Rockers (went from y/t's to stock)
Valvesprings (Rev's to ETP's)
Pushrods (different length, still 3/8 in diameter)
I had a pushrod that kept coming out from under a rocker. Luckily it did not bend the intake valve. Dan/Jim @ Speed Inc. have a lot of turbo combos under their belt and I am fortunate that they have seen some combos NOT work and know what to check. I'm hoping to run this weekend.
Old Nov 9, 2006 | 03:57 PM
  #85
qqwqeqwrqwqtq's Avatar
-Also removed the anti-surge compressor housing.
Old Nov 9, 2006 | 04:14 PM
  #86
LS1Tech Co-Founder
Hi Jim. Does the timing look the same as last time? Any major changes? I"m guessing that driveability improved quite a bit now.
Old Nov 9, 2006 | 04:47 PM
  #87
LS2Camaro's Avatar
nice numbers PSJ you are definitely due for some good track times. Im sure that you will do great next time out.
Old Nov 9, 2006 | 04:59 PM
  #88
LS1Tech Co-Founder
Those guys have done a killer job with the car, I will take a lot of pictures and vid next time. The kit looks oem on the car.
Old Nov 10, 2006 | 09:00 AM
  #89
LASTLS1's Avatar
6 Second Club Moderator
AWESOME!!!!!!!!!!!! Now your ready for action!!!
Old Nov 10, 2006 | 09:57 AM
  #90
LS1 SPEED's Avatar
he wants action with you Sunday @ Byron
Old Nov 10, 2006 | 10:05 AM
  #91
LASTLS1's Avatar
Motor is out.
Old Nov 10, 2006 | 11:01 AM
  #92
Willem @ Fuel Injection Concepts's Avatar
so NOW you remove the A/S? didnt i tell you to do it when you ordered the turbo and when at the time of order it is a free option from PTE?
Old Nov 10, 2006 | 11:21 AM
  #93
craigbb's Avatar
why so much boost..speed inc has done ton of cars with the TTi race kit T76 those are making 850-900 at 18psi w.bs3..
Old Nov 10, 2006 | 11:52 AM
  #94
LS1Tech Co-Founder
I'm an A3, I think you are comparing me to a lot of M6 cars.
Old Nov 11, 2006 | 07:46 AM
  #95
LS1 SPEED's Avatar
Default Question
WILL THE CAR MAKE IT INTO THE LOW 9's TOMORROW WITH THE ROOKIE ?
Old Nov 11, 2006 | 10:55 PM
  #96
LS1Tech Co-Founder
Barring snow and poor driving, we'll see what happens tomorrow.
Signed,
The Turbo Rookie
11.6@127
Old Nov 11, 2006 | 11:00 PM
  #97
LASTLS1's Avatar
With your turbo kit! It should run a 8 right off the trailer! If he can 60' it I say it will run a 8.9-9.1
Old Nov 11, 2006 | 11:19 PM
  #98
LS1Tech Co-Founder
Thanks for the pressure Andy.
Old Nov 11, 2006 | 11:22 PM
  #99
kp's Avatar
kp
Well good luck tomorrow, shouldnt you be getting some sleep instead of playing around on the internet ;D
Old Nov 11, 2006 | 11:31 PM
  #100
LS1Tech Co-Founder
I had a few Red Bulls so I'm waiting to get sleepy.
You around tomorrow?
By Brett Foote | 2026-06-04 05:00:17
