Hose keeps blowing off!!
Take your pick...
SC-
1) You need a larger BOV. If your BOV was not designed for that type of boost then you will still pressurize the intake tube on decel.
2) A simple T-bar clamp will fix MOST of your problem. ALL good F/I systems should only run T-bar clamps. The basic ones are JUNK..
I still use cheap worm clamps on 18psi of boost and never blew a hose off
Just weld a good bead and have enough BOV
They actually Tig'd a bit of welding rod around the pipe to create a lip ( stainless in this case )
BOSS APPROVED!
