A little advice....2-Step
Old Nov 6, 2006 | 12:26 PM
JD_Z28's Avatar
Default A little advice....2-Step
I just installed my Synergy 2-Step and was wondering how you 6spds are lauching with it. I've tried mashing the gas and dumping the clutch and it seems to spin through first. would it be a better idea to just half throttle it and feather into the gas or lower my rpm settings and floor it? The last time I tested it, it was set at 3k. Any help would be nice
John
Old Nov 6, 2006 | 12:36 PM
2MUCHBOOST's Avatar
The 2 step is really only valuable if you have slicks and can hook. Otherwise it just there to burn tires
Old Nov 6, 2006 | 12:54 PM
JD_Z28's Avatar
I run it with Hoosier ET Streets. I just wanted to know what technique everyone using, half throttle and feather in it w/ 2 step set at high rpm, set at low rpm and floor it all the way, ect.
Old Nov 6, 2006 | 12:57 PM
98turbls1's Avatar
I think that the whole point of a two step is to be able to WOT it to get off of the line quicker...Just turn it down a bit and see how it reacts...
Old Nov 6, 2006 | 01:02 PM
Frost's Avatar
If you are trying this on the street you can forget about it...
Old Nov 6, 2006 | 01:04 PM
98turbls1's Avatar
Also, you have to remember John that Qualcomm isn't the best prepared track around so that could be part of your spinning....I don't even know if they do anything to it... Just food for thought...
Old Nov 6, 2006 | 01:05 PM
black98ws6ta's Avatar
If you are spinning on the track maybe you need to lower the rpm. If you are trying it on the street then it will not do any good unless the car is set-up to hook on the street.
Old Nov 6, 2006 | 01:13 PM
JD_Z28's Avatar
The thing is if I set it any lower I'll get out of the whole quicker but i'll be a out of boost for a second I tried setting it at 2500 WOT and dumping the clutch, it jumps hard but then takes a second to hit boost. I figured I could set it higher (3K rpm's) go about 3/4 throttle, dump the clutch and move into the gas. Do you guys hold it full throttle and dump the clutch or do you use a diffrent technique.
Old Nov 6, 2006 | 01:14 PM
JD_Z28's Avatar
The point is to be able to build boost and not have the car bog on you. I could still go 3/4's throttle build boost and get out of the hole smooth.
Old Nov 6, 2006 | 01:18 PM
The point of the box is to go wot and be able to dump the clutch. Ive used the same box on 10 cars with no problems. You need to work on your suspension, get a better hooking track, or turn the two step down in small increments.
Old Nov 6, 2006 | 01:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Street and strip are a big difference.
Old Nov 6, 2006 | 01:47 PM
JD_Z28's Avatar
Would you guys say its a bad idea to go 3/4's throttle and feather into it. What RPM is ideal? I know it all depend on track, suspension, boost, ect.
Old Nov 6, 2006 | 01:58 PM
ABeasst's Avatar
I plan to try mine out at 4K and see how it hooks (at the track) then go from there.
Old Nov 6, 2006 | 03:05 PM
JD_Z28's Avatar
I couldn't hook at 3500 but our track sucks
